Old 04-26-2021, 07:59 AM   #15
wmancil
wmancil's Avatar
Drives: 2018 Chevrolet Camaro RS (current)
Thanks for all the feedback. Performance with the 3.6 is not really an option, however better sound is and $$$ is at this point which is why I was looking at Flowmaster versus a higher end system.
2018 Camaro RS - current
1976 Corvette - sold
1979 Formula Firebird - sold
1970 Camaro SS - sold
1978 Firebird - sold
1974 Nova - sold
wmancil is offline   Reply With Quote
Old 04-30-2021, 11:53 PM   #16
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
Far as a review on the Corsa...well that is going to be a bit. I ordered it on December 9th and I am still awaiting shipment.
How do you like the Corsa compared to NPP and the Flowmaster?
Old 05-01-2021, 08:16 AM   #17
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Still waiting on parts to finish it up. I decided to change some things up. Going TSP headers with off road connection pioes into a Borla X pipe with the 60608 reasonated mid section...then into the Corsa NPP.
I started looking at the stock X and decided I wanted to get rid of all the areas that necks down. The afm valve area is under 2.5". Since I am FI, I want to keep the exhaust flowing best as possible to help with cylinder temps.
Old 05-01-2021, 08:39 AM   #18
Mark114
Mark114's Avatar
Nice! That should be an awesome exhaust system when you get it finished.
Old 05-05-2021, 11:04 PM   #19
KingLT1
KingLT1's Avatar
I decided to install the exhaust without the headers since they haven't showed up yet. The Borla 60608 resonated x pipe works perfect with the Corsa NPP. Ill probably install the headers this winter and upgrade the injectors all at once. I haven't had anytime to drive the car yet. I just started it and let it warm up, then retorqued all the clamps. Very happy with the fit and finish of the exhaust. It's also very tame with the valves closed. I'll get some sound clips soon.
Old 05-06-2021, 06:26 AM   #20
Chrome383Z
Chrome383Z's Avatar
Drives: 2019 Camaro 2SS
Sweet! Looks good. Curious to see how it sounds with headers once you get there too.
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
Chrome383Z is offline   Reply With Quote
Old 05-06-2021, 07:49 PM   #21
KingLT1
KingLT1's Avatar
Here is a start up vid with a few revs with the valves open and closed.
Old 05-06-2021, 08:05 PM   #22
NYblack1le
Drives: 2018 1SS 1LE
Wow very quiet in stealth. I’m still on the fence about swapping out npp but the raspy tinny sound kills me.
NYblack1le is offline   Reply With Quote
Old 05-06-2021, 08:14 PM   #23
KingLT1
KingLT1's Avatar
Yes stealth is very quiet. The video doesn't really do the exhaust any justice because of all the reverb and echo in the metal building. I'll get a another vid outside. The rasp and tin is nothing in comparison to the stock NPP with cat deletes or headers.
Old 05-06-2021, 10:39 PM   #24
Rekkless
Drives: Carmaro SS 1LE
If you're worried about rasp, make sure the mid pipe is 3" and ad a mid muffler, like the Magnaflow X-pipe mid muffler. It will keep the volume loud but clean up the tone, get rid of the rasp and tinny sound.
This guy here on the 1LE facebook group made a rasp free custom exhaust that just sound glorious. Add a Corsa NPP muffler for the perfect stealth when you need it.
https://www.facebook.com/groups/6thg...57786014792318
Rekkless is offline   Reply With Quote
Old 05-07-2021, 10:52 AM   #25
NYblack1le
I have the magnaflow sitting on the shelf. Need to find an exhaust shop that I can trust with the car.
Old 05-07-2021, 12:48 PM   #26
KingLT1
KingLT1's Avatar
Here are some vids for those that might be interested.
1) Cat delete pipes with stock Npp
https://youtube.com/shorts/hJwkLjtZvt4?feature=share
2) CA delete pipes with Flowmaster NPP
https://youtu.be/yM3TfAVCaP8
3) CA delete pipes with Borla Resonated X and Corsa NPP
https://youtu.be/SNWc8mF1O0Y
Old 05-07-2021, 03:35 PM   #27
This is the sound of maximum freedom
Old 05-07-2021, 03:43 PM   #28
KingLT1
KingLT1's Avatar
Just went out for a drive and the Corsa setup is absolutely amazing. So clean sounding inside the cab. No drone at cruising speeds even with the valves open. Very throaty sounding part throttle and screams bald eagles @ WOT. Close the valves and it's stock NPP quiet.
I would definitely put the Corsa NPP in a nother league above the Flowmaster as it should be for the cost. The Flowmaster is still great for the money but I would suggest spending the extra if you can swing it!!
