#15 | |
![]() Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE Join Date: Feb 2020
Just make sure to hold the throttle all the way down and once the tach goes past 5k push the clutch all the way in and shift to the next gear. The motor will sound a bit funny as it holds the engine speed while you shift. Go practice and have fun. |
#16 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
The stock SS shifter is decent, but I found the Hurst shifter to be significantly more precise. You will not miss a shift with the Hurst setup.
If Hurst wanted to sell a ton of these shifters, they'd put a car on display at Camaro Fest (or similar event) and allow potential buyers to get a feel for it in comparison to the stock shifter.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
#17 |
Drives: Camaro SS 1LE Join Date: Aug 2018
Last night i was watching shifting videos and they all mentioned what you guys are saying—push the shifter forward into third with your palm, rather than grasping the shifter. Drove M since 15.5 yo and never heard of that or had an issue. Oh well, better late than never!
Thanks! |
#18 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
#19 | |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
#20 | ||
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Yup. Grabbing the shift knob almost guarantees you'll pull the lever away from the path you need it to take . . . though I think the old straight-line 3-speed floor shifters actually encouraged people to grip the ball.
Norm
'19 WRX 6M (the family sedan . . . seriously) |
#21 | |
![]() Drives: 2017 2SS Camaro Join Date: Mar 2015
2017 Camaro 2SS, K&N Air, Borla S-Type, Cat Delete, 1LE replicas, Hotchkis Swaybars, Eibach Springs. ALL BMR arms, end links, chassis braces and cradle lockout. Hurst shifter.
#22 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
yea when i heard you had to almost drop the tranny to install it i was over it haha
#23 |
It's not as bad as it sounds.. you just need to lower the rear of the trans a bit to get access to the shifter. I did it in my garage with no lift over a weekend.
#24 | |
![]() ![]() ![]() Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
https://www.camaro6.com/forums/showp...3&postcount=63 https://www.camaro6.com/forums/showp...0&postcount=60 Stiffer aftermarket motor mounts have been suggested as a possible fix but not sure if anyone with the issue has tried them yet to find out. |
#25 | |
#26 | |
#27 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: like an old lady Join Date: Jun 2012
i think it is also fair to ask the question:
am i missing the shift...or am i letting the clutch out too soon? there is a difference and knowing what's what will make solving the problem easier. i don't miss gears but i have noticed the rubbery, soft shifts (since new) and as of about 10k miles the shifter got noticeably loose (23k miles now). the car still shifts very easy and what i would call precise. however, in neutral, the shifter moves around about as much as the zf5 does in my 88 f250. i can see that much slop causing a problem when trying to NLS @ 6900, although it has not stopped me. edit: i bought a hurst last year and will install it this spring. i know ill never get the t56 mgw feel i'm looking for, but the lack of shifter options for these cars is annoying.
#28 |
Good advice for the 2-3 shift. I also bring my elbow close to my body.
Mods: MSD, Headers, 95mm TB, high flow cats, full 3" exhaust, SPL, MCS 2-way remotes, sway bars, rear diff lock outs, Sparco racing seats, 6 point harness, CMS roll bar, Nine lives wing, 6" splitter, ACS canards.
www.youtube.com/@Racer_Mike87 |
