Old 02-03-2021, 08:18 AM   #15
Z OH 6
Drives: 2024 CT5-V Blackwing
Originally Posted by Dan82679 View Post
Do those PWR bricks offer better cooling? Or are they only high boost applications so they don't collapse?
Supposedly both.
Old 02-03-2021, 08:44 AM   #16
Dan82679
Dan82679's Avatar
Drives: 2017 ZL1
I didn't see any data on PWR page. It needs to be tested on the dyno with hp tuners. A lot of money for snake oil.
Dan82679 is offline   Reply With Quote
Old 02-03-2021, 10:23 AM   #17
JSH
JSH's Avatar
Drives: '20 ZLE
Did you email either of them about data?
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 02-03-2021, 10:45 AM   #18
Dan82679
Dan82679's Avatar
Drives: 2017 ZL1
I did,They said they are waiting on Tangable data from there testing partners but have seen a 10-15 degree difference on all GM cars.
Sounds good but I still need to see hard Data, preferably from a third party. It not trying to be a negative nelly but for that kind of money it needs to be backed up..
As far as the thermal plates and blanket they do keep the SP cooler at start up. I have the Fasterproms plates and the FI thermal blanket on mine and supercharger is much cooler to the touch than before.
Old 02-03-2021, 03:34 PM   #19
Idaho2018GTPremium
Idaho2018GTPremium's Avatar
Drives: 2021 Camaro ZL1 A10
Does anyone know the material of the spacers? Are they aluminum or a material that doesn't conduct heat as well? If they are aluminum, I don't see how they would help, considering they'd be conducting heat directly from the aluminum heads to the supercharger.
2021 Camaro ZL1 A10
2022 GR Supra 3.0
Past:
2018 Mustang GT Premium w/ PP1, MR, and A10
2007 MazdaSpeed3
1995 Pontiac Trans Am
1987 Camaro Z28
Idaho2018GTPremium is offline   Reply With Quote
Old 02-03-2021, 03:37 PM   #20
Dan82679
Dan82679's Avatar
Drives: 2017 ZL1
PVC
Old 02-03-2021, 03:37 PM   #21
Z OH 6
I don't know anyone that makes any for the LT4 but FI Interchillers spacers are more like a high temp phenolic and they do work.
Old 02-03-2021, 03:49 PM   #22
Idaho2018GTPremium
PVC
Definitely not PVC; way too high temps for PVC.
OK, good to know - thanks.
2021 Camaro ZL1 A10
2022 GR Supra 3.0
Past:
2007 MazdaSpeed3
1987 Camaro Z28
Old 02-03-2021, 05:30 PM   #23
Dan82679
Dan82679's Avatar
Drives: 2017 ZL1
I was being vague when I said pvc but it's definitely plastic didn't know we were being specific. BtW we have plastic all over the engine bay and attached to our engines.
Old 02-03-2021, 05:49 PM   #24
Idaho2018GTPremium
OK. But saying "PVC" is not vague - it's a specific type of plastic. There's a lot of different types of plastics and polymers, so you can't say "PVC" when pretending to be general or vague. Some plastics handle heat much better than others.
So, it's some sort of high temperature rated polymeric material, and not aluminum. Got it.
2021 Camaro ZL1 A10
2022 GR Supra 3.0
Past:
2007 MazdaSpeed3
1987 Camaro Z28
Old 02-03-2021, 05:59 PM   #25
Dan82679
Dan82679's Avatar
Drives: 2017 ZL1
I wasn't pretending anything, I work with pvc in my line of work so it comes out naturally for me. Why don't you just call the manufacturer next time.
Old 02-03-2021, 07:17 PM   #26
JSH
JSH's Avatar
Drives: '20 ZLE
I say it's probably a Nitrile Rubber Composite gasket/spacer. So many great composites out there that don't transfer heat. Superchargers/heads would seem to be a good application.
2020 ZL1LE A10.
Old 02-24-2021, 07:23 AM   #27
Z OH 6
Looks like FI Interchillers now has spacer plates for the LT4.
https://fiinterchillers.com/shop/pro...spacer-plates/
Old 02-24-2021, 07:45 AM   #28
JSH
JSH's Avatar
Drives: '20 ZLE
I've ordered spacers and blanket
2020 ZL1LE A10.
