#15 |
![]() Drives: 2018 Camaro 1SS Join Date: Apr 2018
It really isn't bad at all.
Camaro 1SS M6 - LT2 IM, 1-7/8" Speed Engineering Headers & catless 3" x-pipe to Borla ATAK NPP axle back, Mishimoto Catch Can, BTR Rocker Arm Trunnion kit, E85, 95MM TB, JLT CAI, 180* T-Stat, & SJM line lock - Tuned by Ted Jannetty
#16 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '16 Garnet Red 1SS Join Date: Mar 2014
Think the thinness is detrimental in the long term?
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
#17 |
![]() ![]() ![]() Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
I don't think so, I don't see how it would ever cause a crack or anything, I mean unless you ran over something since its exposed on the bottom.
I just can't stand the crappy beat up work truck/van exhaust noise when the engine is lugged and loaded, its makes your 40k+ "sports car" sound like a 1980s van with half a million miles on it. |
#18 | |
#19 | |
Get under the car when its idling, when its safety jacked up of course, and be careful not to burn yourself on the header. Listen to where the sound is coming from on the header and I will bet you will hear more noise radiating from the merge collector area. The factory headers have a cast section at the merges as well. I think we need to focus on these areas, the header collectors are also very close to the ground which amplifies some of the noise back. I haven't ordered any header wrap because its so expensive and I am not convinced its going to do anything, but I think I am going to try some. I did add the magnaflow x pipe muffler like some other members here had, it does in fact quiet it up and a lot more than I though. The ticking and noise from the headers is still there and more noticeable now. |
#20 | |
![]() Drives: 2017 2SS F1FTY Join Date: Feb 2020
#21 | |
#22 | |
https://www.summitracing.com/parts/m...+5ba2887e89302 It should fit nicely in the tunnel right in front on the driveshaft, if you need pictures I can get some. I cut the stock exhaust and put it in place. I will warn you though, it will make it a lot quieter, enough to where you might not like it. I am still not satisfied with my sound, I think you have to sacrifice a lot with long tube headers. There is a lot of bad quality sounds the stock manifolds and exhaust dampens. I think a alot of the problem comes from when timing is pulled during the shift and it brings out the raspy/crappy sound from the exhaust. The magnaflow will help quiet that sound down, but I still think I can detect a lot of it, but most other people probably wouldn't notice. |
#23 | |
Either way, I hear you getting rid of the stock exhaust manifolds and especially cats too make the car sound like crap and like its broken. |
#24 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
I think the borla 60608 is legit for “bad” sound mitigation. Don’t know how it compares to the magmaflow. It is more resonator than muffler tho
#25 | |
Now I think I am regretting that decision and wishing I had put the Borla on. I guess I could still order the Borla just not sure how I would fit it on since I want to do it myself but I don't have a pipe bender and exhaust work is almost impossible to do, at least cleanly of course, without the right equipment. |
#26 |
I've never used header wrap, is all of it about the same? I don't think its going to do much for sound, but I am more desperate for a solution.
#27 |
First timer on header wrap, I had ceramic dougs before. For a daily, maybe would go ceramic but remember them be louder
Dei Titanium wrap on 2” tsp Had them in and out a few times you could say. Making sure the fit was 100% no touching and no chance of clearance issues at full flex I really only wrapped the primaries up before the merge. The merge is where the dirt collects and didn’t want junk sitting there. Also felt it was more important holding the heat in the primary pipe just before it merged..they want you to start wrapping over all four pipes and create a cave concoction...not into it, i ordered more ties and took it as far down the primary as i could and tied it off similar to the top. So yeah kinda opposite your theory for attacking the sound there tho. Not sure on that but the sowing machine ting ting is very little
#28 | |
I really wish there was a company out there that made properly engineered headers that cared about sound quality and maintaining the stock sound suppression characteristics. I'm sure it would probably be way too much money for an aftermarket company to invest in tooling for anything cast. |
