01-28-2021, 05:34 PM | #15 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
Haha. It’s what gm uses as factory fill. Crazy thing is,it and castrol only dexos 2 certified in 0-40 we can get. If you want to maintain warranty.
Mobil one is fine for street use. I used maxima and Joe Gibbs when I had a cam and aftermarket valve train. |
01-28-2021, 10:56 PM | #16 |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
My advice is if you street drive it like a grandma go with the 5-30.
If you street drive it hard, or drag/track it, go with the 0-40. 0-40 is preferred. 5-30 is acceptable.
01-29-2021, 02:14 PM | #17 |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
Guys, 5w30 is only "okay" if 0w40 isn't available. It's available. It's not even that expensive now. Rockauto sells Mobil 1 0w40 ESP for $6.72/qt. There's really no excuse for not running the actual specified oil. Compared to 5w30, it's thinner at cold startup when you want it to be, and thicker at high temps when you want it to be. On Mobil's own spec sheet it lists the kinematic viscosities at 40C (102F, which is basically a cold start on a hot summer day) and at 100C (fully warmed up to operating temps). At cold startup on a hot day it will take the 5w oil 14% longer to reach lubricated parts because of its higher viscosity. At high temps its higher viscosity and higher high-temp/high-shear viscosity will protect those same parts better.
Matt Miller
2020 SS 1LE |
01-30-2021, 06:05 PM | #18 |
Drives: 2021 Camaro SS Convertible Join Date: Apr 2016
Manual for my 21 SS says 5-30, Dexos 2
2015 SS2/RS, SCT Tune (Dynosteve), Vitesse Throttle Controller, Vararam VR-DRX CAI, Vararam Power Wedge TBS, Granatelli Performance MAF |
01-30-2021, 09:03 PM | #19 | |
No it doesn't. The manual for a 2021 says the same thing the manual for my 2020 says:
Matt Miller
2020 SS 1LE |
01-30-2021, 09:51 PM | #20 | |
Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
01-31-2021, 05:14 AM | #21 |
Makis
Drives: 2020 Red Hot ZL1 A10 Join Date: Apr 2019
Loool - that ^
01-31-2021, 05:37 AM | #22 | |
01-31-2021, 06:19 AM | #23 | |
Drives: 2021 2SS Join Date: Jul 2020
The 0W40 ESP has a 40C viscosity of 73 cSt and a 100C viscosity of 13.2 cSt. M1 5W30 at 40C is 64 cSt and 11.1 cSt at 100C. 5w30 is THINNER at 40C. So your point is actually in favor of the 5W30 at those temperatures. The 0w40 has more viscosity at the hot end, though, as expected. The 0W vs 5W rating is a moot point for most people. 0w will have a lower pour point (something like -50C?) and unless your driving in a place that reaches negative temps often, won't make much difference at all. |
01-31-2021, 06:42 AM | #24 |
Makis
2018 Camaro SS
01-31-2021, 08:31 AM | #25 |
01-31-2021, 08:41 AM | #26 |
My ZL1 oil cap has the same 5w30 on it and I am not switching to 0w40 either. Don’t think mine will blow up Farmer Fran!
01-31-2021, 08:54 AM | #27 |
Drives: 2021 300 Join Date: Jan 2015
Use what the cap say's that's what the engineers designed the engine it's on, to run with.. Changes from year to year happens but what is on you cap is for that engine!!!!!
01-31-2021, 08:56 AM | #28 |
Makis
I plan to keep the oil cap and keep using the 5W30 oil recommended on it
