Old 02-07-2021, 03:03 PM   #15
StPeteHyper2.0
StPeteHyper2.0's Avatar
Drives: '16 Hyper Blue 2.0
Originally Posted by JusCrayZ View Post
Checked out your speaker & amp upgrade, very nice and clean on the install. Do you do that regularly or done it in the past for people? Your finished product looks to be of a professional level installation...
I did have (2) questions though:
When looking at the details on the PAC RP5-GM51 page, it mentions the CAM-GM51. Is that necessary or did your back up camera work when you used the RP5-GM52 harness?
Are the Steering Wheels controls retained, both Volume and Track Up/Down?
I've always done my own setups. I sometimes help people with theirs. I don't consider myself a professional at things but I like it clean and take my time with stuff. I work as an architectural draftsman and do structural work. Grew up around houses being built. So I'm good at handyman work as well. I own a hair salon that I've remodeled by myself while in operation. I spent Friday night changing out my friends ATS rear diff from 3.27 to a camaro ss 3.73, then Saturday evening and night at the salon changing wall sconces, light fixtures, and running wires thru the ceiling and walls adding switches and replacing outlets. My car has been thru quite a bit of changes as well. Full bolt on, bigger turbo, custom intercooler, rear SS brake conversion with 15" conversion, 3.73 diff. Audio obviously, lol.. so yeah I don't try to limit my capabilities and like completing things for myself. A little more gratification I guess.
I only used RP5-GM51 with the RP5-GM52 for +'16 gm cars. No need for CAM. The harness retains back up camera and the pioneer unit allows you to access it while driving. The module also retains steering wheel functions for volume and tracking. I did run the mic behind the visor. It doesn't seem to retain the stock mic or the call/end call button on the steering wheel. I'm not even mad tho.. lol also I think there are usb adapters out there but I used the replacement usb setup. Need a rca adapter to the aux of pioneer module. Only one of the usb line I plugged into the radio, the other I bound up with the hdmi and hid it under the ac vents before crossing over to the radio. When you lift the console up, you can peel the carpet down a little and shove it in there.
StPeteHyper2.0 is offline   Reply With Quote
Old 02-15-2021, 11:17 AM   #16
JusCrayZ
Camaro Fifty
Drives: 2017 Camaro LT1
It definitely shows, nicely done.
Thanks for the additional notes here. I wanted to add some additional information that might help the next person who goes this route. There is a USB adapter for retaining the OEM USB/AUX port in the center console.
Metra AX-USB-MINIB
USB to MINI B Adaptor Cable
However, the Pioneer head unit in this thread does not allow the use of a Hub to expand out to multiple USB connections. Maybe it is because it is USB Type A or something along those lines. At least based on the research and different adapters I have tried, I kept getting a HUB ERROR on the Pioneer display when plugging it in. Just a heads up on this.
I did finish the install and the unit looks and works great. I still have the OEM Non-amplified speakers in the car and with this unit, they sound significantly better. Working under the glove box with putting everything back up under there was a bit of a task and required patience.
Also, did you completely swap out the center console USB/AUX Port?
When you removed the OEM USB port, was the cabling intertwined with the other connections in the center console? I have not tore into that yet as I wanted the unit installed and up and running before swapping that connection out.
JusCrayZ is offline   Reply With Quote
Old 02-15-2021, 10:50 PM   #17
StPeteHyper2.0
Nice job. And yeah I had same issue.. didn't get the hub error, but I tried a few ways and only 1 usb would work. I tried a USB splitter also, no go. In the console.. it's wrapped up with the harness but it unplugs from the back of the usb/aux port. Two white tabs to push in and it releases.
Old 05-14-2021, 09:16 PM   #18
Josh24
Drives: 2016 camaro LT
Can u play videos on that radio
Using a usb ??
I have alot of music videos on my
Computer
Josh24 is offline   Reply With Quote
Old 05-21-2021, 06:05 PM   #19
StPeteHyper2.0
Using a usb ??
Computer
Haven't tried videos from usb but I assume it should. You'll need the parking brake bypass to be able to watch videos without the parking brake on. I have played youtube videos thru Android connection
Old 01-29-2026, 09:10 PM   #20
X24amd
X24amd's Avatar
Drives: 2021 Camaro LT1
This is a nice upgrade for base model 7" IOB radio system
Anyone that has swapped car audio before can handle this easily. Swapping the touchscreen display and dash kit is just taking it apart and putting back together. The extension cable can be fed thru the dash down to the passenger floor board. Tuck away the unused stock harness. As for the radio module, it is accessible from under the glove compartment. (4) 7mm screws unmount module pan from the bottom and pull the panel off the side of the dash to access the radio module bracket. All of it will drop down to the floor board and be easy to work with. Only wiring connections to be made are from the PAC module to the pioneer radio harness. Also wire in a parking brake micro pulse bypass to the radio. The PAC harness plugs into the stock radio harness and that's it. Plug in other items (USB, XM, Aux) connections. Follow PAC and Pioneer install directions for wiring. The Pioneer radio receiver fits where the stock radio is pulled from the bracket and can be reinstalled back in the same place. There's a lot of wiring that needs to be zip tied and plenty of space for the harnesses to tuck up in the dash. Screw the bottom pan piece back and reattach the side dash panel and you're good to go. Side note.. the parking brake bypass allows video and certain features to be used while driving. Back up camera is also visible while driving.
Specs:
Pioneer DMH-c5500nex
Metra 108-GM3B dash kit
Other options:
Pioneer DMH-c2000nex / c2500nex
Metra 107-GM3B
Pioneer CD-RGB150E extension cable
PAC RP5-GM51 compatibility module
PAC RP5-GM52 harness for '16+ vehicles
SXV300 for xm connection to receiver.
Axxess AXUSB-GM6 for usb and aux to the console. (There may be usb and aux adapters, but I didn't try them)
Parking Brake bypass micro pulse
Did you lose the backup camera?
Alex
x24amd@yahoo.com
Instagram- alex24dacosta
X24amd is offline   Reply With Quote
Old 02-01-2026, 10:46 PM   #21
X24amd
X24amd's Avatar
Specs:
Other options:
Metra 107-GM3B
Which cable is the back up camera? I have a radio on the way and also the smaller 7-in screen. Is it the small blue USB cable factory harness or the other wide one?
Alex
x24amd@yahoo.com
