#15 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Wild Cherry LT1 Join Date: Dec 2016
I’ve used 303 fabric protector in the past. Seems to work well, beads, top is a nice darker black, cleans easily (especially pollen, blows right off). The stuff stinks, so you may want to wear a mask, if applying. I do get a bit concerned about adjacent rubber or plastic, paint coming in contact with the solution (because of strong chemical smell), so I taped off as best as possible and rolled on twice. I probably would’t apply again, if I didn’t already have some left over taking up shelf space. As others have said, in the garage or top down.
#16 |
![]() Drives: 2017 Convertible 1SS A8 Join Date: Aug 2018
I prefer to use Duragloss 341 convertible top fabric restorer. It adds UV protection, helps repel water, and prevents staining. It’s $15 a bottle and is enough for 3-4 applications. I’ve used chemical guys convertible top protectant too but I wasn’t impressed with their product considering it was $20 and only enough for one application.
Kooks 1 7/8" LT catted headers, Katech Ported TB, SoCal ported IM, Green filter, Tuned by BCP, Borla S-Type axle-back, BMR springs, BMR front sway bar endlinks.
#17 |
![]() Drives: 2017 Camaro SS FIFTY Join Date: Dec 2016
I have RaggTopp cleaner at the ready when needed to remove any stains I may get but have not used it yet. Keeping the top clean and only open it when it is dry has served me well. Still is soft, pliable and looks like new.
#18 |
![]() Drives: 2020 V6 Camaro Vert Join Date: Nov 2020
The owner's manual doesn't say anything about applying any sort of sealant or protectant to the top. If it was truly required - or even beneficial - my theory is that GM would sell their own marked-up brand of it and insist that it's necessary in the owner's manual.
I worry less about rain water causing the fabric to get weird than some weird chemical formula (yeah, yeah, acid rain, yadda yadda yadda). Just my two cents. |
#19 | |
![]() ![]() ![]() Drives: 2016 SS Convertible Join Date: Sep 2016
I think this may be a similar scenario. I try to wax my cars once a year. That said - I've only used the top protection product once. Seems for me it's a once every few years application since the car is garaged and doesn't see much outdoor time with the top up or any rain or weather. |
#20 | |
![]() Drives: 2016 Camaro 2SS Convertible Join Date: Sep 2016
To answer the OP's question in the title of the thread, "Is it neccesary to put a sealant on the VERT top?" - No, it's not necessary. However, if your car is anything but a fair weather driver and gets driven with the top up at all, I would certainly recommend using a protective product.
1996 Camaro Z28 with T-Tops (Sold 10.22.16) 1986 Camaro IROC-Z with T-Tops (Sold) 1961 Volkswagen Beetle with Sliding Ragtop Sunroof (2009-Present) 1964 Volkswagen Beetle with aftermarket Sliding Ragtop Sunroof (Sold) Follow me on Instagram - @gen6_2ss_vert |
#21 | |
![]() Drives: Camaro 2020 2SS VERT Join Date: Dec 2020
#22 | |
That being said, I hear what you're saying, and I'm not 100% convinced either way re: what the best method for taking care of the vert top is. I see some vert tops on the road that look absolutely terrible - and some that look decent, even on older cars. I really wish I knew what the true difference-makers are between the two. This is my first convertible, and I've only had it since September - so I am by no means an expert. I wish someone would conduct an exhaustive study (see what I did there?) on what people with terrible looking tops did wrong. One thing that concerns me about using some general convertible top sealant is that it isn't custom engineered specifically for the material our tops are made of. Yes, you can lump different tops into broad categories like 'cloth' or 'vinyl' - but each manufacturer probably (and I could be completely wrong here) uses a different blend of materials for each: there are different types of cloth and different types of vinyl. Again, I feel pretty lost on this subject myself, so I'm interested in any and all insight that comes out of this discussion. |
#23 |
ya - same boat here. I have no clue. It's my first soft top convertible. And none of these 6th gens have been out there long enough to be able to determine what works best.
So I think we are all guessing based on prior experience for some or research - but of course the companies trying to sell these products have a point of view that may or may not be genuine. |
#24 | |
Hot Camaro
The complaints about the convertibles in the sixth gen cars are that the window has delaminated and/or the entire mechanism has broken down due to a variety of different little issues. Since many of these have been solved by complete replacement of the top, that further shortens the average tracked lifespan of a convertible top. |
#25 | |
Hillbilly Highness
Drives: 2001 S10, 2022 LT1 Vert Join Date: Jul 2018
The folks who make the material used in the top DO recommend the use of a sealant/protection product. Here is the link: https://www.haartz.com/cleaning-guide/cloth-top-cleaning. Is this just marketing? I tend to doubt it, but maybe? Either way, this is what I based my choice off of and I haven't had any issues to date (knock on wood). That being said, I would be comfortable with 303 and Duragloss products as well because I have used products from both of these companies on other things and they are both excellent from my experience. I just chose Raggtopp because the manufacturer said to and I was lost with this in the beginning too! Ox. |
#26 | |
Hot Camaro
#27 | |
#28 |
![]() Drives: 2018 Hyper Blue 2SS convertible Join Date: Aug 2017
I give it 2 coats of 303 Fabric Guard every spring clean up. I use the liquid and apply it with a small foam paint roller.
2018 HBM 2SS CONVERTIBLE A8 |
