Old 01-05-2021, 07:26 PM   #15
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
...who knows what our buddy keeps in the trunk for maximum traction on his million hp monster ZL1—could be sandbags, could be lead
A few laps around lime rock will do it Also got air over the up hill section in the rear, definitely pushed the suspension hard
This was before I got all the BMR stuff back there so it may not have happened with them.
Old 01-06-2021, 08:33 AM   #16
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Thanks for the explanation!
'20 ZL1 Black "Fury"
Old 01-06-2021, 05:56 PM   #17
JT Camaro
JT Camaro's Avatar
Drives: 2018 ZLE
Appreciate the info...debating if I want to move the harness before I start tracking the ZLE next season
JT Camaro is offline   Reply With Quote
Old 01-07-2021, 05:38 PM   #18
Mark R
Drives: 2018 ZL-1
What BMR stuff did you get and how do you like it?
Old 01-07-2021, 06:50 PM   #19
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Control arms, upper/lower trailing arms, toe rods, and rear cradle lockout.
Plenty of reviews on these things, make a world of difference in the rear.
Old 09-25-2021, 07:40 PM   #20
KILLA BEE
Black lightning
KILLA BEE's Avatar
Drives: 2021 ZL1 1LE A10
Originally Posted by JT Camaro View Post
im amazed you rubbed on stock tires..makes no sense
Something do t sound right at all with that
[ 2021 Camaro ZLE 10 speed
KILLA BEE is offline   Reply With Quote
Old 09-28-2025, 02:23 PM   #21
Bolt on
Drives: Chevy Camaro
Does anyone know what this harness is called I burned through mines
Bolt on is offline   Reply With Quote
Old 09-28-2025, 03:27 PM   #22
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
Thanks for the post. I'm going to be doing this soon myself for some Mickeys.
Did you use heat to flatten the liner or something like that?
radZ28, for Mickey's? What size are you going to run? I didn't do the 15" conversion. But I'm running the 17x10 Weld Solana Beadlock rears with 305/45/17 Mickey Thompson ET Street R and didn't need to modify anything, not even spacers or longer wheel studs. I love the fitment of these on my 2023 ZL1 !
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
