#15 |
![]() ![]() ![]() ![]() ![]() Drives: 17 SS a8 Join Date: Feb 2010
That 76 might be the biggest you can fit if that frame. Anything bigger would probably take some fabrication. I say run it and see where it runs out.
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
#16 | |
![]() Drives: 2019 Camaro SS 1LE Join Date: Jul 2020
garret has a "boost adviser" calculator that you plug parameters into and it spits out something i cant afford lol.
#17 |
![]() Drives: 2016 Camaro 2SS Join Date: Feb 2020
Dropped it off yesterday and will see where it's ends up on power as is. Debating high ram, but other than that everything is purchased and just waiting in line.
16 Camaro 2SS - Turbo 7675CEA
85 Grand National - 03 Sierra - Prostreet TVS1900 |
#18 |
![]() Drives: 2018 1SS 1LE Join Date: Dec 2012
#19 |
Old badass
Drives: 14GMC 2.9 16GMC Turbos 2020Silv.6.2 Join Date: Mar 2020
I like the hi ram but what about an MSD for these (relatively) heavy late model rides. Wouldn't it have a wider torque band and peak a bit sooner? Hi Ram's sweet spot is 5-8k rpm iirc. Either way I love a turbo build!
#20 | |
![]() ![]() ![]() Drives: 2016 Camaro SS Join Date: Sep 2018
Sent from my SM-N986U using Tapatalk |
#21 |
Honestly, the high ram debate for me is just cosmetic. I like the look or black high ram through hood with back wheels. Not a max effort built for track, but it'll def see some RPMs pending how far the fuel setup takes me.
It will allow for easy port injection later if I decide to go full send.
#22 | |
![]() Drives: Turbo 6.2 Join Date: Feb 2019
2016 Twin Turbo Camaro SS - 968hp/970tq 8.9@153
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 |
#23 |
I do not like the look of an intake sticking through my hood and that's why I went with the Procharger intake so I get port injection that is under the hood. Plus I'm running an Anderson Composites carbon fiber hood so I didn't want to have to cut it. I had this plate made for it to match the build.
![]() Sent from my SM-N986U using Tapatalk Last edited by Umbriel; 01-27-2021 at 04:34 PM. |
#24 |
Both valid points, and I hadn't priced the PC intake, I'll have to look it up. Good call.
May just stick with stock until I go full PI, we will see what they find after teardown...
#25 | |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
#26 |
Thanks, I had to take the one that said Procharger to a local guy with a laser cutting machine and he made one of out plastic and then sent off the diagram of it to a place that could cut it out of metal, then we took it to another place that could coat it. The first guy did all of the fonts and everything.
He also made me a section out of acrylic with LEDs to go under it, I just haven't taken the time to wire it all up yet but it will look pretty cool at night when I raise the hood. ![]() ![]() Sent from my SM-N986U using Tapatalk |
#27 | |
I love the texture. Nailed it. |
#28 |
The Procharger intakes are 2500 without fuel rails and 3000 with fuel rails. Nice intake but very expensive.
How much power does it make? Any WOT vids?
