#15 |
![]() Drives: 2017 Camaro 2.0T, 91 Miata Join Date: Jan 2020
Unless you can crawl under the back of the car to the rear axel, and actually function under there, then yes, you'll need to jack up the car
#16 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 Porsche 911 Turbo S Join Date: Jan 2017
IG: 2fast2nick
-- Current -- 2012 Porsche Turbo S - PDK - Basalt Black Metallic -- Past -- 2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101 2015 Mustang GT PP - Whipple Supercharger |
#17 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
Don't get overly concerned - this happens often to many differentials. It just has to do with changes in temperature, the pressure inside the housing and how the vent tube/cap allows pressures to equalize or not fully equalize.
#18 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
the differential itself is not pressurized as there is a vent on the top of the case. The tubes which enter the lower portion is for cooling the differential using transmission fluid...this circuit is pressurized but separate from the differential fluid.
#19 |
this was from the differential case, where the differential fluid is. The differential cooler from the transmission is inside the case, but that doesn't open when you drain the differential fluid.
IG: 2fast2nick
#20 | |
Yes, the vent allows relief of that pressure, but can sometimes allow a small, residual vaccuum (negative pressure) to be rendered when the vehicle isn't in use. That is the hiss. It is normal. Happens with "jiggle-cap" vents. Manual transmissions will do it too. |
#21 | |
IG: 2fast2nick
#22 | |
2018 ZL1 1LE
Drives: 2018 ZL1 1LE Join Date: Aug 2017
The car needs to be level, regardless whether you can do it with or without jack stands. Good Luck!
Current: 2018 ZL1 ZLE
Memories: 2017 50th Anniversary Camaro Convertible (Sold) 2003 Dodge Viper (Sold) 2005 Lingenfelter Corvette (Sold) 2004 Mazda RX-8 (Sold) |
#23 |
![]() ![]() ![]() ![]() Drives: 2020 ZL1 1LE Join Date: Sep 2012
Hissing sound here too...
