#15 |
![]() Drives: SWXXZL1 Join Date: Jul 2020
or it could just be part of the injection molding process.
"Joe" does a hilarious impression of a slinky toy on stairs.
#16 |
![]() ![]() Drives: 2016 2SS, Red Hot, NPP, Nav, M6 Join Date: Jul 2016
[QUOTE=Wobble Goat;10927826]Those 2 "air veins" smooth the air over the Mass Airflow Reader. If you remove them, you will have idle issues. (I know this because years ago I did the infamous "de-screening" on my GTO.) To resolve the issue on my GTO I went maf-less and got a Speed Density Tune.
GOOD aftermarket intakes keep those fins. https://youtu.be/gYdRNjFof8U?t=406 I certainly accept that explanation on the existing "air veins" intent. However my (very old) memory of fluid dynamics leads me to also consider the shape of the veins, as both ends appear by photo to be blunt. And blunt increases turbulence. Turbulence decreases efficiency. Granted not by a lot, but since the Dremel is out anyways, why wouldn't some taper of the leading/trailing edges be considered? My thought here is wouldn't tapering the leading and trailing edges preserve the design intent, but also decrease potential for added turbulence caused by the blunt edge faces in the airstream one is trying to optimize? I get it for production cost and ease of manufacturing purposes, but thinking that a shape like an airplane wing or propeller may be more efficient vs. a blunt leading and trailing edge in a device meant to increase airflow. Just a random thought from a retired engineer... |
#17 | |
![]() Drives: Camaro 1SS Join Date: Jun 2020
[QUOTE=BrianL;10928560]
#18 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: like an old lady Join Date: Jun 2012
[QUOTE=Wobble Goat;10928564]much of a change in airflow at all will result in poor performance without rescaling the maf. my car lost 7 mph at the drag strip with a cut airbox. i made 4 passes that night. went back the next week with the stock box back on and it was where it should be. the performance hit was also mirrored in some pulls i made on the highway with another car.
#19 |
Has anyone measured the stock airbox inlet opening versus the RotoFab? Curious if there are any differences in square area.
#20 |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS Join Date: Aug 2016
On the cut airbox thing, there was a track test of a cut airbox with a green filter vs a rotofab cai on an SS posted a while back. Thread here https://www.camaro6.com/forums/showthread.php?t=517532
#21 |
Yeah, I read that. Too many variables in a drag strip run. Looking more for physical measurements or flow bench data. Doesn’t seem to be any amateur flow benchers on this forum.
“In God we trust, all others must bring data” |
#22 |
Flow bench numbers would only suggest that something could potentially make more power. That test showed us something far more important than flow bench numbers, namely, that the actual performance of the car was better with the rotofab than with the cut box/green filter combo. As far as the variables, the poster of that thread noted the atmospheric conditions, and the cut box/green filter actually got a small advantage of a better DA than for the rotofab. Meaning, a small advantage was effectively given to the cut box/green filter combo, but the rotofab still beat it.
#23 | |
#24 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
My point is, in consideration to the OE tune/not changing the tune, I started to mess with the vanes and I didn’t like where things were going and felt it unwise to go further without a better way to measure minor changes to understand what I was doing. Like I said, hell, maybe knocking the whole thing clean does the trick, where 80%, 90% drops power due to weird flow... If you look at the Vararam videos, you can see a snapshot of the CFD they ran on their box, which is very similar to the OE box. Their box seemed to be completely smooth, but it’s hard to know how similar, internally, it is to the OE box. I’d mainly be curious in regards to the bottom box. |
#25 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro SS 1LE Join Date: Aug 2018
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler. 2018 Colorado zr2 - zr2 sport bar, showcase spare tire. 2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace. 2017 Corvette Grandsport (sold) - untouched. 2006 GTO (sold) - iat relocation, air box mod, monero side marker lights. |
#26 |
i studied the vararam videos. what i took from them was they could not, in honesty, offer an air box better than a cut stock one. at least not one to merit a $500 price tag.
there's a fair chance i'll have my car on a dyno again this spring. ill take my cut air box with me and swap them while it's on the rollers. i did exactly that with a stock tb and a ported tb last year. the car gained nothing from a ported tb. bolt ons only.
#27 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
#28 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 LT1 10 speed auto Join Date: May 2013
Modded my stock air box to pull air from below the stock air intake while keeping the the stock opening functional also. Pulls no underhood heated air this way and have extra air volumn inside the air box with all the grates removed. This provides access to air cavity in front of the wheel house down low and there is a constant source of fresh air while driving from factory air inlet and my opening.
