#15 |
Drives: 2018 ZL1 1LE Join Date: Jun 2012
Fuse pull and be done.
#16 |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
So just so we cap off this discussion the ONLY valves that should be opening or closing are the NPP valves in the rear tip section of the exhaust. The hardware for the AFM is there but not active nor does it have valves that close or open. The M2W switch allows you to choose whether to have the valves open at the push of the button no matter what mode you’re driving in. Last question, if you close the valves with the M2W switch will it then go back to “stock” as in activate and deactivate with each mode that is selected?
#17 | |
![]() Drives: 2017 1SS Hyper Blue Join Date: Apr 2017
#18 |
![]() Drives: 2019 ZL1 Crush Join Date: Jan 2019
What hardware are we talking about here? There is certainly no hardware in the exhaust for AFM
Fuse pull will keep the NPP valves open all the time
2019 Crush A10
E-Force 2650 670WHP 615WTQ All besides the 2650 is bone stock down to the air filter. |
