Old 12-07-2020, 06:42 PM   #15
CHASLT1
Drives: 2021 Camaro LT1
Originally Posted by lt4camaro View Post
What week was your car built in November? mine was built 11/02. I would hope the engines with the bad valve spring batch were assembled in early October, either used in earlier vehicles and or fixed before they went out on the assembly line.
Mine was built in Sept. Not sure of the day.
CHASLT1 is offline   Reply With Quote
Old 12-07-2020, 08:08 PM   #16
Venomcustom
Hard to want.
Venomcustom's Avatar
Drives: 2020 red hot 1SS 1LE
Another thread with a bad valve spring (most likely). Must have sent ya back into a panic. Lol you should be fine at 500 miles.
I feel for the OP as that really sucks.
Venomcustom is offline   Reply With Quote
Old 12-08-2020, 09:17 AM   #17
spitz
Drives: 2021 SS lt2
What month was the car built. That info is on the door jamb decal
sept 2020
spitz is offline   Reply With Quote
Old 12-08-2020, 09:47 AM   #18
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Dealership likely won't replace the engine if the valve didn't drop due to the broken spring. They will likely change all the valve springs and change the oil. Broken valve spring normally doesn't send metal through the entire engine either. So I wouldn't be too concerned about a replacement engine unless it dropped a valve.
Old 12-08-2020, 09:48 AM   #19
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
Originally Posted by spitz View Post
sept 2020
So maybe the engine and heads were assembled in August, is that before the bad spring batch? My engine probably assembled October sometime, not confident on that being after the spring issue and have only 100 miles on my 2021 built 11/02
lt4camaro is offline   Reply With Quote
Old 12-08-2020, 11:28 AM   #20
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
If I’m not mistaken the bad valve springs were put in the V8 engines.
Old 12-08-2020, 02:53 PM   #21
spitz
Drives: 2021 SS lt2
motor
just left the dealer my 2021camaro ss broke a valve spring the dealer ordered 16 new springs not sure when the springs will come in. doesn't seem to be anymore damage at this time. service guy said they will know more when the springs come in and the job starts.
Old 12-08-2020, 06:51 PM   #22
lt4camaro
lt4camaro's Avatar
That certainly is a bummer, would make me feel like crap. When was the car built? and how many miles? if you dont mind sharing.
Old 12-09-2020, 02:50 AM   #23
spitz
Drives: 2021 SS lt2
car was built sept 20th 2020 it now has 321 miles on it
Old 12-09-2020, 09:07 AM   #24
lt4camaro
lt4camaro's Avatar
It seems all the Valve spring breakage is well before 500 miles. I would guess, your engine could have been assembled in august or early sept.
Old 12-09-2020, 06:19 PM   #25
CHASLT1
A C8 just went BOOM at 1000 miles. So i am still waiting for the BOOM.
Old 12-09-2020, 06:44 PM   #26
lt4camaro
lt4camaro's Avatar
Caused from a broken valve spring? or something else?
Old 12-09-2020, 06:50 PM   #27
CHASLT1
Valve spring. Seems more than a few are going boom. So i gotta wonder if i am ok at 1000 miles or 5000 miles?
Old 12-09-2020, 07:06 PM   #28
lt4camaro
lt4camaro's Avatar
May need to know when these LT2 corvette motors were built? they maybe all august september built motors? I would hope any motors built after mid october wouldnt have valve spring issues ( wishful thinking) I am on the Corvette forum, I may have missed some of the valve spring activity.
