Old 05-22-2022, 05:51 PM   #15
Dexterpoole2014
Drives: 2022 ZL1 A10
Good luck! Glad to help!
Knock on wood, I have not had a single issue since the ECM flash was completed (per the TSB)...
did you show the tech the TSB and request that he do the ECM Flash? only reason im worried is because my car is tuned by Brett at Pray Performance and i have some e85 in the car lol
Dexterpoole2014 is offline   Reply With Quote
Old 05-22-2022, 05:53 PM   #16
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
I did show them the TSB and basically demanded they do the flash, even though I cleared the codes, I showed them the picture of the dash which showed the same issue...
If you're tuned, you may have an issue, but either way, even if they void your warranty, they should be happy to do the ECM flash for a price...
Old 05-22-2022, 07:27 PM   #17
Dexterpoole2014
how long did it take them to do it?
Old 05-22-2022, 11:53 PM   #18
2SS Capt
2SS Capt's Avatar
I think I was at the dealer about 1.5 hours total.
Old 09-17-2022, 12:02 AM   #19
kingwale
Drives: 2017 SS
I just had the same issue did you ever get it fixed?
kingwale is offline   Reply With Quote
Old 09-17-2022, 09:02 AM   #20
2SS Capt
2SS Capt's Avatar
Yes, there is a TSB out where they reflash an ECM with updated software, hasn't happened since...
Here is the TSB: https://static.nhtsa.gov/odi/tsbs/20...81687-9999.pdf
Old 01-07-2026, 12:11 AM   #21
2SS Capt
2SS Capt's Avatar
Further update... My 2020 2SS now has 11,500+ miles on it, have not experienced this issue since the first (and only) time it happened (5+ years ago and 8,500+ miles ago), the ECM flash seems to have permanently fixed the issue... Hope this helps someone...
Old 01-07-2026, 02:12 PM   #22
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
[IMG][/IMG]
I'm going to use your picture as my wallpaper.
Old Yesterday, 10:06 AM   #23
ctrlz
Yes, both the car and photo are gorgeous.
I believe he has posted photos in older threads, very much worth checking out!
