#15 |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
I kinda agree with you both but...at the same boost, if one blower is smaller and spinning it's little heart out vs a larger blower that is spinning much less and pushing more air thru...then even tho they are at the same boost I kinda suspect that the larger blower will make more power. If anything then it will be due to less heat. Not for nothing, but GM had to do a lot of alterations and revisions on the LT4 blower to get it to operate similar to the outgoing LS9. And the LT4 blower is kinda maxed from the factory.
But I would say it mainly depends on cost. If money is an issue then sticking with the stock blower might be better. If money is no object then go for the blower swap. I chose to go with the bigger blower because down the road I might want more in which case it would be wasting money if I spent anything on the stock blower. The 2650 and even the 2.9 Whipple will easily make over 1000 to the wheels. So for an extra few thousand bucks it is worth it to me. For someone else it might not be. |
#16 |
The biggest concern is cost efficiency. The way I see it, why have the car down twice and the same work done over again, and wasting money on the stock blower just to in the future discover that you want more? Doing a blower swap means downtime, taking a whole bunch of stuff off...might as well go ahead and do a cam and ported heads and LTs and the whole shebang while you're in there. Do it all once and call it a day. Otherwise if you do decide to turn it up you're gonna end up paying more in labor costs. A blower swap by itself with no other mods is not really a cost effective mod for our cars. Maybe for the Hellcats and GT500s it is. But we need other stuff to get the most benefit from the blower. So just do it all.
#17 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
There is another layer to consider, OCTANE, these engines are Knock Limited at stock boost levels on pump gas. Of coarse that all goes away on Race fuel or E50. This is why following my recommendation of Power through efficiency is so beneficial it raises the Octane Limit of power. Ted.
www.jannettyracing.com
#18 | |
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
Agree 100%. Which is why I went straight with the blower first. Most people I know that did all that work on their stock blowers are now pulling them off and swapping blowers. Ted your package is good I admit, but you need to Run ethanol. As I said it’s not available in most places. It’s great for keeping mostly stock with simple bolt ons as you said like headers etc. Knock issues can be addressed by mixtures of race fuels and/or additives like Boostane or race gas. |
#19 | |
I am not knocking your choice but if you have not addressed the efficiency on the exhaust side you are throwing shit against the tide. I would love to sell everyone a 2650 but unless the supporting mods are in place it doesn't make sense until they are. Ted.
#20 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
#21 | |
Dyno Show Queen LOL
However you will notice while you beat on it, it keeps pulling and pulling vs the 1.7 just doesn't have that much in the upper band. (probably because it can't move that much air but most likely from IATs getting hot and timing starting to interfere)
#22 |
Dyno Show Queen LOL
Question for Ted..
Any information on just installing the maggi with a fuel system like the XDI or a Eforce w Port injection? just wondering looking at some of the ZR1 builds they are making good numbers w headers, pulleys and bigger injectors not even going inside the motor.. Seems like the money saved on a cam swap could go towards a fuel system maybe come out better if its a number someone is shooting at?
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber Last edited by EDFHOBBIES; 11-30-2020 at 01:25 PM. |
#23 |
I can tell you that going from a 2300 Maggie on 17-18 lbs of boost and went to the 2650 Maggie on 14 lbs of boost and made over 80 more rwhp. There were absolutely no other changes other then fine tuning and larger pulley change. That was on a 80mm pulley since no one was making a 75 or a 70 yet. Same fuel, same timing but we tweaked the PE. We also went from 150 degree IATs to 110 logging each run at the track and on the dyno. Plus went from 9.80s@140 (2300) to 9.41@146 (2650)and its run faster since those days. The new owner has been in the 9.30s letting off and mid 5.80s 1/8 with my tuning. I never pay any attention to the dyno numbers compared to track times, you need the dyno for fine tuning. Wish I had it back, my C7 feels pretty slow running 11.18@125.
#24 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1SS NFG A8 Join Date: Aug 2017
I can see that because the 2300 runs hot even at 14psi let alone spinning to where it's making 18psi on a H/C car.
2016 NFG 1SS A8
#25 |
For sure.
#26 |
![]() Drives: 2020 camaro 2ss 10 speed Join Date: Mar 2020
I live in Italy, I don't have E85 unfortunately...
The main problem is if I broke something the car will wait months before a part comes, so I want to stay as reliable as possible. I saw a CSP video about a callaway zl1 that claims to have 750 hp just by changing the SC, but Janetty says or other people, it's too much for stock fuel capacity, so I can consider to port just stock SC, snout, add a 103mm TB with Roto fab, interchiller and headers and upper pulley...should have 650 rwhp (maybe more, standard Italy fuel is 95 octane), I opened the thread because I was thinking of changing only the supercharger with the maggy 2650 'cause of a better cooling capacity and also because it is bigger, so I would have changed only a catback and the car would have remained with the usual sound without exaggerating and attracting the attention of the police here, but seeing videos I was wrong, or maybe I can put a bigger upper fuel pump without add a booster pump ( but I couldn't solve the problem) |
#27 | |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
The European fuel rating is different from the US. You would have to run 98 EU fuel, to be equivalent with 93 US! I have a pulley and tune on mine, runs good, but I already want more.. lol I also looked into just putting a 2650 on mine, but after some research I deceided, to do cam, heads, new oil pump, low side fuel pump booster etc. along with it. With an aftermarked camshaft you will address the fuel issue. The high pressure pump is driven by a camshaft lobe, that can be increased with a different cam. If you don't have anyone around you, that is capable to work on your motor, there is a guy in Austria that does great work on LS and LT engines. Google Heinz Schenk ccrp https://www.coolchevy-raceparts.com/...e-contact.html Do you have a ZL1, or SS? Your profile says 2020 SS...
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel. Elite tuning, results coming soon. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: Swisstyphoon1980 |
#28 | |
I own and operate a speed shop I built my Personal ZL-1 1Le so it can do everything to the best of it's ability. I found all the inefficiencies and eliminated them which rewarded us with a very efficient power package that will maintain max performance under the most grueling venues. Reliability is at the forefront of my decisions on part selection. No pullies, No porting, not aftermarket heat exchangers, interchillers needed. The more stuff you change the more risk you induce. Your 95 octane is the same as our 91 octane so you will be knock limited no matter what you choose and more boost will hurt you more than help you. I am bringing over 40 years of building performance vehicles to the table here, What you do with the information is up to you. Ted.
Tags |
camaro, magnuson, supercharge, zl1 1le tune, zl1 tune |
