Old 10-25-2020, 07:46 PM   #15
avarshav
avarshav's Avatar
Drives: 2020 SS 1LE 6M, 24 Nissan Frontier
Thanks for all the input here everyone. Exactly why I come here.. so long story short, maybe some sound improvements, but no hp gains without a tune.. fair enough!
avarshav is offline   Reply With Quote
Old 10-25-2020, 08:39 PM   #16
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
Originally Posted by avarshav View Post
if you do the secondary dat delete, does that cause a check engine light?
No it does not. Unless you manage to get an exhaust leak during the process, then you will get a CEL.
Right, no CEL so no tune needed.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 10-25-2020, 09:27 PM   #17
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
correct just delete your rear cats or do a axle back. Headers or just hi flow cats require a tune and you already have shorty headers. GM can cancel your warranty just seeing you illegally removed your stock cats. Want to fight it in court. You removed emissions components so you loose. Even if the component you replaced didnt cause a the failure you will have to fight it in court for years and thousands of dollars. you want to keep warranty dont touch cats forward. rear cats wont void warranty though as a cat back will not. Rear cats are a commiforia thing.
Old 10-26-2020, 09:49 AM   #18
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Camaro has shorty Tri-Y OEM headers. Stay stock until you want to tune.
