Old 10-18-2020, 05:52 AM   #15
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
To to Summit, got it in two weeks even though they had it listed as sold out. Agree on Matthewamels points. This not ATF and I was told basically the same info.
Timbo-1LE is offline   Reply With Quote
Old 10-19-2020, 03:51 PM   #16
SloCal
SloCal's Avatar
Drives: 2018 2SS 1LE
Does anyone know if you can definitively top it off with the Tremec MTF fluid? I'm having 3rd gear issues with Redline D4 ATF at high rpms where I can't get into 3rd easily and have seen a couple mentions of this fluid fixing that but not a lot of info on the actual use of the fluid with the TR6060 online despite how many cars the trans is in.
Chevy seems pretty adamant about the 8oz take out when filling
Thanks
2018 1LE
2nd 6th gen
SPL Toe Arms/Brembo HTC64t/Corsa NPP/Tremec MTF Fluid
SloCal is offline   Reply With Quote
Old 10-19-2020, 03:57 PM   #17
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
The tremec tech told me to drain it complete. My view, they engineered this, so their fluid should be the best... Reminder this is not ATF, and assume ATF keeps cost down for the OEMs and work for 99.5 percent of their customers....
I did drive it about 100 miles on Saturday to heat cycle new tires and bed in new pads, I can tell a difference.
Old 10-19-2020, 04:13 PM   #18
SloCal
SloCal's Avatar
Drain it completely ie. a different method than just using the plug below the fill plug? I'm worried there's going to be some in the lines or something leftover
I don't use the drain plug above the crossmember -- I've just done the drain plug below the fill plug with the temp sensor on it typically -- is that what everyone here is doing?
2018 1LE
2nd 6th gen
Old 10-19-2020, 04:15 PM   #19
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
emailed my purchasing guy to get me a price haha we have account with summit
Old 10-26-2020, 12:35 PM   #20
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
I was having some issues with the 2-3 speed shift on track, no longer with the Mobil1 ATF fluid. This fluid sounds like it's even better.
Old 10-26-2020, 02:38 PM   #21
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
Good, but the Tremec fluid is not ATF. Will let you know after Daytona this weekend...
Old 10-26-2020, 04:10 PM   #22
carguy55
carguy55's Avatar
No kidding.
Old 10-26-2020, 04:51 PM   #23
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
I use the temp sensor to drain the trans fluid.
'18 1SS 1LE Black, PDR
Old 10-26-2020, 07:18 PM   #24
SloCal
SloCal's Avatar
but if switching to MTF from ATF should we be using the actual drain plug rather than temp sensor when changing fluid ie. a full flush?
2018 1LE
2nd 6th gen
Old 10-26-2020, 07:55 PM   #25
MatthewAMEL
MatthewAMEL's Avatar
If you are going for a full flush, you'll also have to get the fluid in the cooler and cooler lines. So, 2-3x's run and drained.
I didn't do a 'full flush'. I drained using the sensor.
But I do change my fluid every year due to track use. So, YMMV.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
2025 Hysteria Purple
C8 Z07
Old 10-26-2020, 08:08 PM   #26
SloCal
SloCal's Avatar
That's my usual thinking is just over time it'll even out when switching from stock fluid to redline d4 but if people here are saying MTF switch has different expansion properties and you should top off instead of taking 8oz out makes me think it's more imperative to fully flush before running tremec fluid on track?
Otherwise probably like 10% ATF remaining in system cycling through
2018 1LE
2nd 6th gen
Old 10-27-2020, 05:31 AM   #27
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
Concur, as Matthewamel stated, it has residual in the lines. Since in was in for alignment, I just asked the dealer to let it drain a long time since the car was going to be in for two days. Did they actually do it, no idea... Again, I'm looking to see if this helps the "mushy" trying to find third gear after a few long track runs.
Old 11-07-2020, 09:08 PM   #28
BruceWayne1LE
BruceWayne1LE's Avatar
Drives: 2018 Camaro SS 1LE M6
Amsoil torque drive
Camaro 2SS 1LE, MBRP Catback, Mishimoto Catch Can, Rotofab dry, TSP1 7/8” headers,DSX FF, Pray ported MSD, 95mm TB
492WHP 473WTQ
BruceWayne1LE is offline   Reply With Quote
