Old 10-12-2020, 09:10 PM   #15
CHEM2010
Drives: 2018 chevy camaro ss 1le
CHEM2010 is offline   Reply With Quote
Old 10-13-2020, 12:30 AM   #16
Baddawg53
Drives: 17 hyper blue 2SS M6
Originally Posted by Blackkaz04 View Post
The SS 1LE I recently purchased is too loud for my local track. The build is a btr cam, 1 7/8” headers cat delete and the stock NPP exhaust., I’m looking to tone the car down some...not only is it too loud for the track but the crackling and burbling in the exhaust sounds about like gunshots. Anyways, I’m looking at kooks 12-19” race mufflers to add in front on the NPP exhaust.
Has anyone done this? Any other ideas? What’s the difference between resonators and mufflers. I found force resonators for the same price as the kooks mufflers....
I have heads/cam/LT's, borla atak with NPP. To get under track limits I added the borla resonator and the stock NON NPP muffler. I'm sure I'm sacrificing a few horsepower, but it's definitely under the 103 limit and I'm confident bit will be under 95. Trust me, ditch the NPP and go stock non NPP ... It dropped 25+ db revving in my driveway.
Baddawg53 is offline   Reply With Quote
Old 10-13-2020, 05:31 AM   #17
Blackkaz04
Drives: 2006 Z06
I really want to retain some of the NPP function. But we’ll see. after a lot of reading I ordered a magnaflow x-pipe muffler. I think it may do the trick.
https://www.carid.com/magnaflow/stai...vD_BwE#reviews
Blackkaz04 is offline   Reply With Quote
Old 10-13-2020, 07:53 AM   #18
Baddawg53
I spent something like 800 bucks and welded my own custom exhaust with two mufflers per side, now I have a bunch of spare parts in my garage.
I swap out this big suitcase for my atak mufflers after my track day, it's really pretty easy. I don't think you'll find a muffler as quiet as the stock one but I'm definitely gonna be following this to see if it works for you.
Old 10-13-2020, 08:08 AM   #19
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
So, I tried this when I had a similar set up as you on my 5th Gen. Cam, LT's, cats into factory NPP, and i installed the Magnaflow X-pipe. It worked wonderfully to quiet the exhaust down, but for me it added drone.
That really may have just been in my application, so you may have better luck, and I think you will.
Let us know how it goes, I will be in your boat one day.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 10-13-2020, 08:53 AM   #20
Blackkaz04
Drives: 2006 Z06
Yea, I do worry about the exhaust droning but if it does badly maybe I’ll add some resonators
Old 10-13-2020, 12:45 PM   #21
Fraxum
Fraxum's Avatar
Install some 16" resonators in the x pipe.
Agreed resonators. They worked great on my 5th gens with LTs. On my '16 SS running LTs, running them even with cats through the NPP suitccase, was horrible sounding.
No drone though with NPP.
Old 10-13-2020, 03:43 PM   #22
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
https://www.jegs.com/i/Dynomax/289/1...IaArVpEALw_wcB
Old 10-13-2020, 09:19 PM   #23
Blackkaz04
Drives: 2006 Z06
Originally Posted by avalonandl View Post
Have you run this Xpipe on the 6th gen camaro? It’s almost 10 inches wide....not sure if it would fit in the exhaust tunnel
Old 10-16-2020, 09:25 AM   #24
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
No was making a suggestion
Old 10-16-2020, 09:30 PM   #25
Blackkaz04
Drives: 2006 Z06
Gotcha. Yeah, the magnaflow I posted above is about the same thing I think....I last minute decided to add kooks round race mufflers before the NPP exhaust based on the suggestion from the shop that installed the cam. If that doesn’t do it I’ll try the xpipe muffler...
Old 10-19-2020, 07:26 AM   #26
RobbyBeefcake87
RobbyBeefcake87's Avatar
Drives: 2018 Camaro SS 1LE
Thanks. I think I’m going to give the kooks Round mufflers a shot. Now to decide between the 14” and 19”. I’ll post back my results.
What Is a Resonator? While mufflers reduce the exhaust volume, resonators tune the exhaust for a more pleasant sound. Resonators will remove some of the raspy and high-pitched noises from the exhaust but won't do anything to muffle the volume
My opinion is you almost need both with LTs and the NPP exhaust. TBD
Do you have a link to the Kooks 4' mufflers? Looking for something like this for an e46 ls1 swap car so the size of the kooks won't be an issue since I'll only be running one (single exhaust).
EDIT: Never mind, just looked them up real quick.
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler.
2018 Colorado zr2 - zr2 sport bar, showcase spare tire.
2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace.
2017 Corvette Grandsport (sold) - untouched.
2006 GTO (sold) - iat relocation, air box mod, monero side marker lights.
RobbyBeefcake87 is offline   Reply With Quote
Old 10-19-2020, 01:08 PM   #27
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
Does anyone have a picture of what the stock non NPP muffler looks like? I wonder if its the same dimensions? I would really like to see one cut open.
Also I believe there is a lot of sound reduction when revving at idle from NPP to non NPP because the valves are calibrated to be open when the car is not moving so it will be loud when you rev it and people will be impressed, but then close while driving along normally.
I have tried to change the valve positions around with HP Tuners, but I mostly found that there is no in between, its either open and obnoxiously loud at WOT, or closed 100%. There is something about exhaust that sounds good below about 60% throttle, then once you go above that at WOT, the sound quality just turns awful.
cmitchell17 is offline   Reply With Quote
