#15 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
Doing anything to a stock blower, i.e. spinning it faster, porting, etc. is a waste of money, time and effort for a glory number on the dyno that can't be repeated out in the real world. If you could measure the power output from the starting line to the finish line you would better understand what I am talking about. Adding a cam to the stock blower further runs it out of air even earlier. Adding Meth is a last resort after all other options have been exhausted, plus it introduces another baby sitting job and potential failure point. The more you think about it if you want more power than the stock 1.7 puts out then move to a larger supercharger. IMO The heartbeat 2300, the Whipple 2.9 and the TVS 2650 in that order are all good options targeting your power goals. Then you can sell your Stock Supercharger to a LT1 guy whos looking for a nice 150 RWHP upgrade and recover some of the money spent on the new charger. Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
#16 | |
Moderator
#17 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
Are you sure the blower bolts are one time use? I can't imagine this is the case, but I could certainly be wrong, this car is covered up with TTY bolts.
Baby Blue
#18 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
Yes they supposedly are TTY bolts but Elite and other catch can companies reused them after installing the can. Maybe Ted J will chime in on this!
#19 |
![]() Drives: ZL1/1LE parts added Join Date: May 2018
Location: Somewhere around Texas pines tress and smooth asphalt
How much will a cam hurt the stock supercharger performance ? Will it not pull as much up top ? 6200 vs 5800 RPM ? |
#20 | |
A cam increases air across the cylinder head making the blower run out of air earlier. The best analogy I can come up with is like you are jogging down hill
#21 |
Ok ! Thank you I understand !
