Old 10-02-2020, 08:30 AM   #15
Pcormier66
Pcormier66's Avatar
Drives: 2019 ZLE
Originally Posted by sr71bb View Post
While this is true, we found that the changes in toe are not significant enough to require a toe adjustment at the track. Thats not something you can easily do anyway at the track. The toe is set correctly for the street settings on -2 degrees negative camber which of course is what the plates will be adjusted back to PRIOR to leaving the track.
What is your street toe setting? And how much neg camber do you intend to set at the track?
Pcormier66 is offline   Reply With Quote
Old 10-02-2020, 10:50 AM   #16
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
The STREET setting is -2.1 degrees negative camber with .05 TOE IN. Since the increase in camber with the plate is accomplished by pushing in ONLY the TOP of the strut, the change in toe ONCE -3.6 degrees camber TRACK setting is dialed is negligible. So basically TOE IN should be the same.
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 10-02-2020, 11:46 AM   #17
Pcormier66
Pcormier66's Avatar
Drives: 2019 ZLE
I would get toe plates and measure your track toe. It may be more sensitive than you think. Since my car is primarily for track use I set my track specs As the default and let the street setting fall where it may.
Old 10-02-2020, 12:39 PM   #18
sr71bb
sr71bb's Avatar
Not a bad idea. What toe plates would you reccommend I purchase???
Retired Cars BELOW:
Old 10-02-2020, 12:54 PM   #19
Pcormier66
Pcormier66's Avatar
Drives: 2019 ZLE
I have these.
https://www.amazon.com/Longacre-LON5...ag=googhydr-20
Old 10-02-2020, 01:18 PM   #20
sr71bb
sr71bb's Avatar
Ok thanks. What toe settings are you running at the track???
Retired Cars BELOW:
Old 10-02-2020, 05:32 PM   #21
Pcormier66
Pcormier66's Avatar
Drives: 2019 ZLE
0.00
Old 10-07-2020, 12:05 PM   #22
asthmamax11
asthmamax11's Avatar
Wish these guys would come to Georgia
16 1SS M6 White
Magnuson 2.3 Heartbeat
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
02 Z28 M6 35th anniversary
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 10-11-2020, 04:05 PM   #23
LJenkins1LE
Drives: 2018 1SS 1LE
The last time I ran Eagles Canyon was about 7 years ago. They recently redid the surface and it was VERY smooth. The elevation changes were easier to deal with because of the smoother surface.
The two camaros I saw in the RED run group seemed to be lapping pretty fast and they BOTH were 1LE's. I had HARRY's Lap Timer but I never ran any laps with it those two days. There was a ZL1 1LE but he wasnt in the RED group. My instructor ran my car in the instructor grouping and it was surprisenly competitive .
I was there that weekend in red. I posted my PB video from that Sunday in the Best Times thread in this section.
2018 Summit White 1SS 1LE, PDR, Black Bow Ties
LJenkins1LE is offline   Reply With Quote
Old 10-26-2020, 11:18 AM   #24
carguy55
carguy55's Avatar
This is good to know.
