#15 | |
#16 | |
![]() ![]() ![]() ![]() ![]() Drives: '16 Camaro SS 6 spd manual transm. Join Date: Aug 2012
I have the same car, I would say NONE.
'16 Camaro SS
Prior cars: '14 Corvette C7 Stingray Z51 '14 Camaro ZL1 w/. Recaro seats '11 Mustang GT 5.0 w. track package '02 Porsche 911 Carrera '05 Infiniti G35 coupe sport |
#17 | |
![]() Drives: 2017 Camaro 2SS Join Date: Jul 2016
#18 |
It is necessary to tune for headers on these cars...the throttle will close some @ wot if you don't.
#19 |
![]() Drives: SS A8, NPP, Red Hot Join Date: Jan 2019
#20 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
Yeah I have to admit the SS has a way of making higher speeds feel innocent. I mean cruising at 80 MPH unless you are checking the speedo you wouldn’t believe you were doing more than 65.
My other cars (G37, LS3 4th Gen, Toyota Prius) feel like I’m moving at that speed. |
#21 |
These E92 ECU's are torque based. So headers or any significant mod will cause the engine to exceed the torque limits programmed in the ECU. If you make more torque then you have to raise the torque limits or the throttle will close to stay under that limit. The only mods that can be done and not bump into these torque limits is a CAI and ported stock IM/TB.
#22 | |
Also OP, sorry to derail the post. |
#23 |
Yes there there is enough room for those mods without bumping into the torque limit. It's been documented. Just search Pray Performance and start reading up on all his testing over the years.
#24 |
Necessary to see full hp benefit sure, but if you're still under warranty, want some extra sound and a few extra ponies it's fine to run without a tune was my point. When the warranty is up, tune away and pick up even more. I see a lot of posts here where people think the car will run terribly (without a tune) or the warranty will be immediately voided when you bolt them on and that's just not the case.
#25 |
It will run but it won't pick up any power. I just explained why.
#26 | |
Moderator
#27 | |
Moderator
The ECU uses airflow to predict/command/calculate/limit torque. So, changes in airflow profile means the car can now bump up against the commanded max torque and/or its peak torque limit. And it’s not just a limit, the computer commands torque values that dictate how the engine runs, so you can’t just “max out” all the limiters. Getting too close to those limits means spark cut or throttle blade closure to keep calculated torque to what the ECU is expecting. So, any significant mod will need a tune to keep the car running and performing properly.
#28 | |
![]() Quote:
