Old 09-01-2020, 12:48 PM   #15
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
Honestly, for $99 If try the LED conversion. I put LEDs in my daughter's 2019 Elantra and she loves them...
Can you convert HID to LED? It's relatively easy for halogens, but HID has different wiring so it would be a lot of work.
HID lamps are already pretty good, and when you replace them, they will last a good while.
Sent from toaster or something
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 09-01-2020, 12:55 PM   #16
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Not sure but they offer a conversion kit here so I am assuming yes it is possible... https://www.headlightexperts.com/car...sid=0HuzrkTj0o
Old 09-01-2020, 03:41 PM   #17
dmcmahan60
dmcmahan60's Avatar
Drives: 2017 SS
Check these guys out. I have bought 3 kits from them over the years and all were top notch quality!
https://lightwerkz.net/
dmcmahan60 is offline   Reply With Quote
Old 09-02-2020, 12:07 PM   #18
Deputy Dog
Drives: 2017 Super Sport Cam.
Any justifiable reason why Sylvania is selling these stock HID bulbs at $150 a pop? Sounds like highway robbery. I mean I'm all for buying American products but this is ridiculous. I could see if they came with 15 or 20 year warranties, but they don't. Sounds like the are taking advantage of the situation.
Deputy Dog is offline   Reply With Quote
Old 09-02-2020, 12:17 PM   #19
ember1205
Hot Camaro
ember1205's Avatar
HID headlights are typically fairly unique in their wiring setup and power requirements. Converting to LED could be WAY more hassle than its worth.
Start with warranty and go from there. I've only ever had one issue with HID bulbs and it was in my 2015 Sierra. The bulbs originally used were problematic because of how they threw light to the side and GM swapped them to a different brand as part of a TSB. I've never had one burn out.
Old 09-02-2020, 12:43 PM   #20
Nothing like an SS
Faster!!!
Nothing like an SS's Avatar
Drives: 2020 Camaro 1SS 1LE
Sylvania is not actually American, they are a sub division of Osram which is a German company. Sylvania is just the North American operations of Osram......
Just sayin'...it isn't buying American
As to the rest of this thread, I would leave HID as they are, conversion is not worth it.
Nothing like an SS is offline   Reply With Quote
Old 09-02-2020, 01:08 PM   #21
ember1205
Hot Camaro
ember1205's Avatar
This will likely give you everything you need:
https://www.camaro6.com/forums/showp...99&postcount=6
Old 09-02-2020, 03:21 PM   #22
Turkish01
Drives: Camaro
https://screamingchicken.com/2016-18...id-headlights/
My drivers side went out, bought a set of these in 5500k. Working great so far. They say their pure white but do have a slight blue tint to them.
Turkish01 is offline   Reply With Quote
Old 09-02-2020, 03:30 PM   #23
ember1205
Hot Camaro
ember1205's Avatar
OEM's typically use a color temperature in the low to mid 4000's. 5500 is kind of high and will definitely have that "blue" look to them.
Typical fluorescent bulbs are around 4000 if you want another reference.
Old 09-02-2020, 03:32 PM   #24
NeverDie
Drives: 2017 Camaro SS 1LE
Originally Posted by MackSteelPrivateEye View Post
Anyone know why he is disconnecting the cable at the Bulb housing at 1:05 on the 3rd video? Can't you just go directly to removinf the HID cap and swapping the bulb?
https://www.carcarekiosk.com/video/2...ghts/headlight
IF you want to end up in the hospital, sure.
I watched a new tech swap a bulb on my 1999 BMW 328i with HIDs. He didn't disconnect the battery or power cable from the ballast. The car was replaced due to electrical fire and he was taken away in an ambulance.
But you know, you COULD save a few seconds?
NeverDie is offline   Reply With Quote
