#15 |
![]() Drives: 2018 ZL1 A10 Join Date: Sep 2014
I have dealt with CSP for my old car's bastardized tune that was done at another shop. Andrew sat with me and went over every table in HP Tuners, showing me why he was making changes and theorizing what the previous tuner may have been thinking, etc. Long story short, he's a gadget guy and knows his way around HPT and is super friendly and honest. He's also disconnected with a lot of the pricing and business operations, and that is where Alex steps in and does a great job.
Their techs are funny, down to earth, and knowledgeable. I just wish they were closer to me. A 2 hour drive on the highway and in traffic to get to them isn't fun when you're a DIYer just looking for a tune. Your car is in good hands with them. Haven't used RPM personally as my pockets aren't that deep, but rarely do I hear anything bad. When you do, the negative posts/feedback tend to "go away" since they sponsor most forums, or used to. Every good shop will have some negativity though, it's just nature of the business. Avoid a place with too many red flags or throw money away like I did lol.
SOLD! 9/1/2020 2018 ZL1 A10 Hyper Blue - Rotofab CAI, Gibson catback
@SurefireDetail OEM ZLE tails/third brake light, Gen5DIY reverse LEDs, front Amber LEDs, SMG laser LED side markers, SMG smoked reflectors 1994 Trans Am LM7/CPT 4L60E/9" 1987 IROC 2006 Silverado |
#16 | |
Petro-sexual
Another reference: Magnuson's old CEO had an M6 Z06 with an OEM-car, that only upgraded the OEM air box to a CARB-GM CAI and upgraded 5-inch intake tube and 103mm Mamo, and it put down about the same power on 91, around 6500 (he ran it out to near 7000 were it was close to 730). Stock everything else. There's a good video by a Nickey tuner with an A10 ZL1 with LTs, Big Gulp, 103mm Mamo and at about 16-psi, it was near 750, but right on the fuel limit. I believe that was on 93 (it was near Chicago and in Winter), but the fueling and timing were relatively conservative because of the way the driver used the car (a lot of 1320' and a lot of hot-lapping for competition). So those are pretty safe numbers to keep the car happy and safe. IMO - you should always be honest with yourself and start modifications by knowing, at least close, what you want and will be doing with the car. The Nickey customer was drag racing in a series where the competition required hot-lapping the car. So the car was mod'd and tuned with those in mind. The customer could easily go faster, for more money, than that, but the car was built and tuned to how it would be used. If you have a power goal greater than about 750, then you should be looking at alternatives to fueling and make sure you take those into account for the budget of the build. You probably already know all that, so if you're looking for about 750 to the tires, you should get there really easily with basic bolt-ons and a 2650. I bet with good air, good tune (torque tuning is a beesh), good fuel, and good track & traction, 9s shouldn't be hard to hit.
#17 |
Petro-sexual
And to bring it back to CSP - I purchased the 2650 and BG from them, lol.
#18 |
5.5ms on the injectors is plenty safe. I wouldn't worry until you are steadily over 6ms if the fuel pressures are solid.
#19 | |
Petro-sexual
. I've heard 5.5-6.5 but I'm only at the low side and fuel seems to be holding steady with no hiccups. I'd rather stay on the conservative side and play it safe.
#20 | |
![]() Drives: 2017 Chevrolet Camaro ZL1 M6 Join Date: Jul 2020
You mentioned IPW's of 5.5 to 6 as being the limit. A stock cam can do this - Reliably? I'm ok with broken axles and similar stuff, but not a smoked motor. My wife would lose her mind! LOL In the end, having a 9 sec DD would be plenty and way satisfying! Hah! but for how long?![]() Once again, thanks for the well thought out answer. And, by the way, I grew up on 40th and H st., downtown Crapamento. |
#21 | |
Petro-sexual
I wouldn't try to convince you that there's zero risk in running around those values, but it's pretty accepted that MANY people do successfully, and don't have issues. If you're "only" looking for about 700-750 to the tires, it seems like this is pretty darn safe. BUT - if you think you'll want more down the line, I'd make sure to get a cam with a fuel lobe, and you'll be good out another 100-horse' on good gas. I am in the same boat with a blown motor on a new car with the wifey, so I feel pretty confident. They way I see it, I get better efficiency with a larger blower, with a little more strain on the bottom end, but I get less heat and more power, so it balances out pretty well, for me. If you consider LT5, and the relatively minimal changes it is from LT4, maybe that might offer a little more confidence. The crank metal is slightly stronger, and there are new crank and rod bearings, but the rest of the long block (minus a slightly better cam in LT5) is LT4 all the way. It seems like good shops push a stock LT4 out to 1000-RWHP without much issue (with supporting fueling mods' and such), so me making another 100+ over stock isn't going to tax much. I feel pretty safe. It's all in the tune at the level I'm at. NICE!!! I'm just down the road, at Watt and 50, so I'm familiar with your stomping grounds. Congrats' on escaping CA, HAHAHAHA. If I didn't have the ties I do, I'd escape, too... Good luck on your efforts
#22 | |
#23 | |
Petro-sexual
Side note: I change the sentence in my first response, as I missed it on my edit before posting.
#24 | |
![]() Drives: 17 NFG ZL1 17 GTR 22 RS6 Join Date: Apr 2017
CSP has a interesting video they dropped last night where a brand new Calloway ZL1 came in with issues and making only 5xxwhp.
#25 |
Petro-sexual
That's like the second or third Callaway vehicle that it seems like needs tuning that I've noticed. That video was posted one of a Tahoe not all that long ago, too.
#26 |
I almost went with Calloway back in 2017, my thought process was pay big now, but dont have to do much later...lol Glad I didnt and found CSP. *I understand Calloway is a great product, but they do have some lemons out there that should have never made it out the garage.
#27 |
![]() Drives: 2018 Chevrolet Camaro ZL1 6MT Join Date: Aug 2020
I am having it done October 19! The 775 HP package and a cam package. They have been great so far. Answered every question. I email and within a hour or less I have a answer. So far I give them 5 stars. Covid 19 is delaying things, but that’s not there fault.
#28 |
It is 750 crank. I have same package from them but also with flex fuel ,DSX auxiliary pump.On 93 I got 625 wheel with a manual.They say Automatics get more HP on this car. With E40 I get 650 Wheel. Don't listen to the mmix reviews. I've been there to meet the mechanics and Andrew and there all good at what they do.
