Old 08-11-2020, 07:35 AM   #15
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
DO NOT use a pressure washer or compressed air on a radiator. You will damage the fins.
Turtle wax bug and tar remover is surprisingly effective at softening hard, sun-baked bug splatter and carapace, FWIW.
Old 08-11-2020, 09:16 AM   #16
Mark R
Drives: 2018 ZL-1
Noted. Thanks.
Old 08-11-2020, 09:32 AM   #17
ZLE dude
Drives: '18 ZL1 1LE
Originally Posted by Vigilante375 View Post
Wait until you find a bird.....
I've had to pull 3 birds out of the front of this car in the past year. Not sure what the deal is, but I've only hit 1 bird up until owning this car in the past 20 years! It's like a bird vacuum.
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
ZLE dude is offline   Reply With Quote
Old 08-11-2020, 07:26 PM   #18
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Originally Posted by TWG1 View Post
Also, any tips on removing the protective screens on the lower side coolers? Seems that leaves and loose debris gets stuck between the heat exchangers and the screens that protect them. If I could just get the protective screens off...
This is the problem area I have also!
Old 08-11-2020, 09:43 PM   #19
Those giant gaping holes in your ZL1 lower grille, man, that's what attracts them
