#15 |
Long hauler
Interesting, I’ve had my K&N intake for a few months now. Sometimes I’ll get the RPM’s hanging but not all the time. I’ve reinstalled it once and actually broke one of the fittings on the tube (K&N kindly sent me a new one) in an attempt to remove any leaks. I’m kinda paranoid about it but will check one last time
2016 1LT v6 - Totaled Happiness: Infinite |
#16 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Camaro 1LT Join Date: Jan 2016
the "ecm learning" how the throttle body position relates to the commanded torque the computer is asking for is why these kinds of mods have a limited impact on performance outside of WOT ...and may even limit impact of wot performance gains.
The computer commands torque. If it suddenly gets more than expected, it adjusts down until it gets what it wants. Quick back to back tests at a dyno or immediate judgements after an install would be misleading, since the computer hasn't had time to adjust and learn. Tuning is needed to give you a higher torque ceiling where needed. i'd suspect the only benefit that will remain until a tune is response...since the throttle has to to move less for the same commanded torque changes as before (basically a similar benefit gauze cone filters provide over paper stock) |
#17 |
![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro V6/RS Join Date: Nov 2018
Just for reference I have a Flowmaster axle back, CAI, and ported throttle body. With the stock tune my 0 to 60 is the same as stock. I even use the same stretch of road, and in very similar conditions, to make it as fair as possible. I'm convinced that the stock tune will simply adjust (within reason) so measurable gains can be had. Now on the other hand through response, and part throttle power are significantly improved, so it's most definitely worth it in my opinion
#18 | ||
Long hauler
#19 |
trifecta's always a good option ...though there are a few other options these days as well that offer more hands-on free updates to their tunes as you mod.
A tune shouldn't hurt mileage when you're cruising (however it can hurt it in traffic if you like accelerating ) I get mid 30's at 80mph ..and have hit over 40mpg going out to AZ (both the to and from drive) and my 0-60 that i did a few weeks ago was 5.4s and I'm stock except for a cai and very loud exhaust.
#20 |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
I haven't seen it mentioned yet, but the holes are 1/8" NPT, just get yourself some plugs. You should be able to get them at any good auto parts store, or hardware store. I'd probably put some silicone on the plugs myself.
That is an overkill unit by the way, so I wouldn't attempt to remove the TB adapter piece. |
#21 | |
Long hauler
#22 | |
Long hauler
#23 |
![]() Drives: 2015 Camaro 1SS Join Date: Dec 2017
NPT/MIP has tapered threads, so you shouldn't need any silicone to seal it.
#24 | |
Long hauler
#25 |
Long hauler
I finally stopped being lazy and installed it, off the bat I thought I messed it up since the RPM’s were going 1200-1600 and kept fluctuating. But a drive around and now I definitely have more low end RPM fun and the exhaust is deeper sounding. Almost like a cold start but instead of idling off it consists with the deep volume
No CEL’s after 20 minute initial drive, only noticed that when I am cruising and let off the accelerator it blips like 100 RPM first. Also Sport mode, the little I tried, has the RPM’s more higher on less input. Snow and Ice feels like touring but it’s still learning. No tune still.
#26 | |
#27 | |
![]() Drives: 2016 Summit White Camaro LT2 RS Join Date: Jun 2016
After I installed the Soler ported TB (76mm), I experience that same little rev bump if I'm cruising and let off the gas. Seems harmless and Soler didn't seem too concerned. I have the overkill tune but have never managed to get Will to retune specific to my car. Not sure if its something that he could tune out or not.
2016 Camaro 2LT | 3.6L V6 | A/T | Summit White | JWM Smoked Side Markers | Flowmaster American Thunder Axle-back Exhaust | K&N Filter | AIRAID Modular Intake Tube | Overkill Tune
#28 |
Long hauler
I bought the combo from someone on the Facebook v6 group for $500. I didn’t realize then he was supercharged but the screws I posted earlier are perfect thanks to the measurement given by Jacfab.
Someone said they had to cut their silicone reducer and I did, it’s practically the same length as the one that came with my K&N intake. This is how much I had to cut all together, with my K&N one above
2016 1LT v6 - Totaled Happiness: Infinite Last edited by Bumbleboy92; 09-04-2020 at 06:06 PM. |
| Tags |
| 80mm, intake manifold, ported, throttle body |
