07-27-2020, 12:57 PM | #15 | |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
07-27-2020, 12:58 PM | #16 |
07-27-2020, 01:10 PM | #17 |
Drives: ISO ss 1le Join Date: May 2018
How certain are you that the alignment rack is 100% right? I had a similar issue at my favorite race shop (been doing my alignments for years) and it wound up their machine was way, way off. They had to have the hunter rep come in and calibrate the machine.
Worth looking into... |
07-27-2020, 01:13 PM | #18 |
Drives: 22 1SS 1LE Summit White Join Date: Sep 2016
No, more like the adjustments were never the same.
#53 F Street
2022 Sponsor autocrossdigits.com Autocrossing Videos https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag Instagram: apexit_53 2022 Rapid Blue 1SS 1LE 2019 D Street national champion (2019 civic Type R) |
07-27-2020, 01:25 PM | #19 | |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
As for the accuracy of the alignment rig, TrackClub indicated that it was checked in two different shops. And yes, eccentric alignment adjusters are indeed the devil, or at least the spawn of the devil. Slippage (i.e. not holding their alignment) is the biggest problem.
Matt Miller
2020 SS 1LE |
07-27-2020, 01:37 PM | #20 | |
Drives: 1LEs Join Date: May 2009
07-27-2020, 01:47 PM | #21 | |
Indeed the feedback from 2 shops has been the same. They can't even get to 1.5 camber wise. At 1.4 the toe is at almost 0.3 OUT and they cant bring it in never mind getting anything in toe IN position. Had a meeting today, with the tech that spent 2.5 hrs on it yesterday (their best apparently) and the service manager. He did try to suggest warrany wont apply as 1.1 camber is achievable and that is "good enuf". However, i pointed out this is a 1LE model with $8.5k track option and hence it must achieve what GM officially specs for alignment wise right in the High Performance Supplement manual. So, they will take it up with a regional manager, to spend some time under warranty to see if they can identify the issue. We shall see how it goes...Cheers! PS To say i am aboslutely pissed off is an understatement, as i have stopped the break in process now and this issue can casue me to lose a whole season (shortened as it is already). |
07-27-2020, 02:16 PM | #22 |
It's worth noting that the 2019 Camaro Models Track Preparation Guide specifies rear camber for an SS 1LE at "-1.5 plus or minus 0.15" for "optimized road course usage." This is the same as called for in the 2020 Chevrolet Camaro High Performance Owners Manual Supplement. So there are multiple publications that cite camber numbers you can't reach.
Matt Miller
2020 SS 1LE |
07-27-2020, 02:16 PM | #23 | |
The car was on 2 different racks in 2 days. Same result. But who knows? Another item to add to the list Thank you! |
07-27-2020, 02:44 PM | #24 | |
07-27-2020, 02:57 PM | #25 | |
If that cradle were crabbed at 1-deg to the left, then to get proper thrust alignment you'd need an extra degree of left toe adjustment available. That extra degree isn't available on our cars when we try to dial in max negative camber. The test for this (aside from the alignment pins RUQWIKR mentioned) would be to see if you can get way more than -1.6 camber on the RR while still keeping toe in spec. Or put another way, if you ignore thrust alignment and only focus on total toe on the rear, can you get -1.6 on both sides and keep total toe around zero (albeit with the thrust angle being off)? If so, and if the links and tabs are straight and measure correctly on the cradle, then the cradle is crabbed away from the thrust centerline. Keep in mind that this isn't about whether the cradle is shifted sideways or fore/aft too much, but rather one of whether it's turned a bit off the thrust line. If that's the case, then the fix might be as simple as loosening the cradle bolts, setting the cradle straight ahead, and tightening the bolts.
Matt Miller
2020 SS 1LE |
07-27-2020, 03:23 PM | #26 | |
Unfortunately, i am not at all familiar with these parts, so you guys will have to spoon feed me and i greatly appreciate it in advance! At this point, the didnt do any experimenting at the dealer, apart from trying to get me an alignment according to my specs. As such, i dont know how much more camber they could have achieved on RR. All they told me that side was super easy to get 1.6 and 0.05 toe in. On the LR, the tech said he could only get max 1.4 camber even without any toe adjustments. And when he got the 1.4, the toe out was at close to 0.3 and he could not budge it in AT ALL. Anyhow, that's all I know at this point. Hopefully GM will authorize some time to investigate/experiment under warranty. If and when that happens, i will pass all the suggestions to them. Please keep them coming. Thank you! |
07-27-2020, 03:43 PM | #27 |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
Sounds like the rear cradle/subframe isn't in alignment to me. I hope it's as easy as loosening and retightening some bolts... Good luck!
07-27-2020, 03:44 PM | #28 |
