Old 07-11-2020, 10:48 PM   #15
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
Originally Posted by zain View Post
Check the alignment. Had similar issues
If they have to adjust the rear alignment make sure they have new bolts. Some of the rear suspension bolts are TTY and shouldn't be used a second time as discussed in this thread.
https://www.camaro6.com/forums/showthread.php?t=502324
Old 07-12-2020, 05:46 AM   #16
zain
zain's Avatar
Drives: ZL1
thanks for the link! never thought that those needs to replaced
zain is offline   Reply With Quote
Old 07-13-2020, 08:50 AM   #17
Spellbound
Drives: 2K17 SS Camaro
I have the G2's on my Stock 2017 SS, In my opinion, they are horrible and will never buy again. There is one positive, I cut my best 60 foot with them, 1.8x, they suck every where else, lol.
Duane
2017 50th SS
12.28@114 Bone Stock
12.005@117 Bone Stock with a DR
2018 ZL1 A10, no times, wife won't let me race it.
Spellbound is offline   Reply With Quote
Old 07-13-2020, 09:26 AM   #18
L78toLT1
L78toLT1's Avatar
OP has a ZL1, he probably doesn't have runflats
Baby Blue
Old 07-14-2020, 08:30 AM   #19
SteveV
SteveV's Avatar
Drives: 2018 ZL1 Camaro 6M Red Hot
It is not "probably". The ZL1 does NOT come with run flats. Period.
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
SteveV is offline   Reply With Quote
Old 07-14-2020, 11:57 AM   #20
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
How has no one said this? The NT555s are GARBAGE! You have a world class 200TW front tire and garbage on the back, there's your problem.
I had to look up the 555G2 just to be sure and it looks like they did switch them to a 200TW tire except all sizes with a W speed rating are 320TW and clearly still garbage. Your size 315/30R20 is W speed rated.
Old 08-07-2020, 03:43 PM   #21
malvada
Drives: 2020 Camaro ZL1
Quick update on this, I ordered the OEM size Goodyear supercar F1. Will receive them in a few days and I will update for reference if anyone has the same issue.
malvada is offline   Reply With Quote
Old 08-07-2020, 03:52 PM   #22
Evolvedx27
Evolvedx27's Avatar
Drives: 2017 ZL1
Nobody should be putting anything but a OEM tire, toyo r888r, or michelin pilots on their cars. Depending on your needs/wants.
Evolvedx27 is offline   Reply With Quote
Old 08-07-2020, 04:16 PM   #23
ExorsistzL1
ExorsistzL1's Avatar
Drives: 2018 zl1 10 speed
I have 18zl1 and i 1st put Nt05r 315 35 20 in rear and oem front and my car was throwing codea TC lighting up randomly the car wasn't happy. I switched to toyo r888r 315 30 20 and the tc issue was gone but the car was driving funny so i threw toyos r888r in front and its perfect except for tire hums really loud
ExorsistzL1 is offline   Reply With Quote
Old 08-07-2020, 04:26 PM   #24
Evolvedx27
Evolvedx27's Avatar
Drives: 2017 ZL1
I have OEM in front. Toyo r888r in 315/30 in rear. No issues.
Old 08-07-2020, 04:35 PM   #25
Flowtie1
Drives: 2017 ZL1
I just put on et street ss and I hate them on the street. The rearend feels less settled and the sway is terrible. They hook incredibly well. I bought a second set of my rear wheels and a new set of the factory supercar 3 from goodyear
2017 ZL1 M6 Silver Ice Metallic
Flowtie1 is offline   Reply With Quote
Old 08-07-2020, 04:43 PM   #26
MartinLe
MartinLe's Avatar
Drives: 2017 Chevrolet Camaro ZL1 M6
So, you think that little bit of height difference caused all the trouble? Was it just the codes or did the car drive weird? I was thinking of replacing the rear NT555G2's with the NT05R's (they only come in the taller size in twenties). The fronts will remain NT555G2's. The four NT555G2's seem to stick to the road well in turns and such. But, the rears seem to not want to hook on the street when launching the car. I am searching for a better hook but, don't want a wonky driving missile.
MartinLe is offline   Reply With Quote
Old 08-07-2020, 04:50 PM   #27
19Nasty1le
Craig
19Nasty1le's Avatar
Drives: 2019 ZL1 1LE
Alignment bolts are 1 time use and yea it matters because I re used mine and they shifted bad...
19Nasty1le is offline   Reply With Quote
Old 08-07-2020, 05:26 PM   #28
MartinLe
MartinLe's Avatar
So, you're thinking it was an alignment issue?
nt555, tires, zl1
