Old 07-06-2020, 09:57 PM   #15
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Originally Posted by DorkMissile View Post
You can use a razor blade to score the plastic line and get the fittings off the line, then use some 3/8" hose
+1 on this, but if you broke one of the fittings, I believe you'll need some 1/2"
line and clamps. If you can re-use the fittings you're good to go with 3/8th's line.
The "clean" side is just that- it doesn't emit nearly as much crap back into the intake manifold. GM addressed it pretty well with a little factory catch can of its own. I've got a Mishimoto on the dirty side on my car and left the clean side alone. Just put an appropriate sized piece of tubing back in the same place and you're good to go.
Ventmaster is offline   Reply With Quote
