Old 06-30-2020, 03:58 PM   #15
Yves ZL1
Yves ZL1's Avatar
Drives: Canadian 2019 BLACK ZL1
Originally Posted by 19Nasty1le View Post
Using google translate lol;
il devrait y avoir une clé spéciale pour ces écrous de roue de verrouillage dans la boîte à gants, oui ordinaire.
Not easy to explain : I got the key to lock them
I just would like to know if they are well mounted ?
They seems to not to be to thé right place... they seem to be not screwed till the end ?
Am I clearer ?
Yves ZL1 is offline   Reply With Quote
Old 06-30-2020, 04:13 PM   #16
Narly 45
Narly 45's Avatar
Drives: 2019 ZL1 1LE
Nice! Congratulations!
Narly 45 is offline   Reply With Quote
Old 06-30-2020, 04:21 PM   #17
Yves ZL1
Yves ZL1's Avatar
Thanks for the translation...
What I don’t understand some Of us expressions ..
Old 07-01-2020, 08:31 AM   #18
FalconerOneSeven
FalconerOneSeven's Avatar
Drives: ZL1
Congrats on your purchase and I applaud your courage owning this Camaro in France. I wouldn't want to pay France's gasoline price or the taxes just to own this vehicle. Also the entire country is riddled with radars and speed bumps like a god damn land mine..well my impression when I visited last year. Anyway Cheers!
FalconerOneSeven is offline   Reply With Quote
Old 07-01-2020, 03:29 PM   #19
Plasar
Drives: 2017 ZL1 Vert M6
Smile
Yves:
Felicitations mon ami, c'est magnifique!
Plasar is offline   Reply With Quote
Old 07-02-2020, 01:04 AM   #20
Yves ZL1
Yves ZL1's Avatar
You are totally right !
And I’m Not sure I could drive for a long time cause more the days pass and more the law is restrictable...
Just about the lug nuts... could you tell me if it’s ok ?
Old 07-02-2020, 01:17 AM   #21
Biscuit.fr
Drives: Red hot ZL1 A10 2017
Tes écrous antivols sont des longs, ils sont bien montés.
Il en existe des courts.
Il suffit d’en changer si l’esthétique te dérange.
Biscuit.fr is offline   Reply With Quote
Old 07-02-2020, 03:33 AM   #22
IntimidatorZ
IntimidatorZ's Avatar
Drives: 14 Silvy 1500 Z71; 20 Camaro ZLE M6
Yves ZL1, also using Google translate here:
J'ai un ZL1 1LE et j'ai remarqué que mes pattes arrière semblent dépasser plus loin que les fronts. Je ne sais pas pourquoi, toutes les cosses ont été vérifiées et serrées conformément aux spécifications. Je n'ai eu aucun problème jusqu'à présent. Vous pouvez toujours retirer les ergots et le couple selon les spécifications, juste pour être sûr.
IntimidatorZ is offline   Reply With Quote
Old 07-02-2020, 05:18 AM   #23
FalconerOneSeven
Drives: ZL1
I would personally prefer a anti theft lug nut with the similar mass than the other one, meanwhile I am not sure how one heavier lug will affect the balancing of the system...
Old 07-02-2020, 11:05 AM   #24
Mize442
Mize442's Avatar
Drives: Current driver AMC emlin X 5ltr.
That lugnut looks like its installed correctly. It is a special locking lugnut and its longer than the other ones. You should only have qty1 per wheel
Mize442 is offline   Reply With Quote
Old 07-03-2020, 12:39 PM   #25
19Nasty1le
Craig
19Nasty1le's Avatar
oui c'est ok, le contre-écrou est plus long que le normal. vous devriez avoir 1 écrou de blocage par roue
19Nasty1le is offline   Reply With Quote
Old 07-03-2020, 08:29 PM   #26
wwiiavfan
Drives: 2017 1SS Hyper Blue
Take those locking lug nuts off and throw them away. They will fail you at the worst time, when you are on the side of the road somewhere, probably in the rain. Had a set on a car here in the frigid Midwest US, and got a flat tire in the dead of winter. The little locking adapter would just slip in the nut and wouldn’t come off. Had to have the car towed home where I welded a socket to the lug nut to get it off. Never again.
wwiiavfan is offline   Reply With Quote
