Old 06-15-2020, 04:51 PM   #15
Theseal
Drives: 19 zl1
I’ve won big events in the car, and it’s bone stock. That said, the best results were in an extremely smooth track.
I’m not some noob and I am not hating on the car. I love the car.
But I’m 2800 miles in and 2 strut failures already. My friend who tracks his car extensively is on I think his 4th strut.
So even if they were fast I’d be looking for better alternatives.
However, this thing is radically stiffer than my race car, it has way too much compression stiffness, and cornering speeds are significantly better in non zl1 Camaros with much softer shocks in many corners - per data.
GM does a lot of things well. It does not always release perfect stuff.
Ps - I missed a constructive post - sorry for that.
Anyway any info on shock alternatives is welcome.
Don’t the mag ride shocks require wiring and a module? I don’t think that’s a viable option.
Still need camber too, so it may be aftermarket only options.
Theseal is offline   Reply With Quote
Old 06-15-2020, 05:01 PM   #16
Theseal
Drives: 19 zl1
Yes too stiff for the track. By a lot. I have probably twice the spring rate on my race car and it has way less compression damping especially at high piston speeds.
I don’t drive it on the street at all and don’t care how it rides.
I do want it to be faster, safer and more reliable on track. Softer damping would accomplish all of those things.
It is so stiff it skitters over bumps and actually impairs vision in some places, such that cornering speeds suffer, and safety is also an issue as if you enter rough patches at the limit on the gas, the results get unpredictable and the frequency is so high that you are having to make major corrections to reel the car in, instead of just working the tires properly.
As far as ‘buying the wrong car’ comments, GM did not make available the fact that these struts are only good for 1000 miles, nor did they let me drift the car into a bumpy corner at 100mph at full throttle, so those comments are pretty dumb.
Old 06-15-2020, 05:18 PM   #17
cirpower
Drives: Camaro ZL1
I am pretty sure you can have the OEM shocks modified to give you softer dampening. You can pretty much do that with every shock. I would try to contact the manufacturer.
cirpower is offline   Reply With Quote
Old 06-15-2020, 05:48 PM   #18
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
not with these lol they are dssv shocks
Old 06-15-2020, 05:56 PM   #19
cirpower
Drives: Camaro ZL1
Are you saying that Multimatic does not have the ability to set the damping of their dampers? It might not be a viable option, but I am fairly certain that it can be done.
Old 06-15-2020, 06:15 PM   #20
kropscamaro16
i believe they can do that but do they offer that service to the public? not sure
https://www.multimatic.com/structure...ers-road-cars/
Old 06-15-2020, 06:19 PM   #21
DemonZL1
199
DemonZL1's Avatar
Drives: like a granny
Driving style plays a role on shock set up, that's why adjustable coilovers are typically the go to. Perhaps that's what you are needing?
I have not heard of any strut failures (aside from a leaking ZR2 multimatic strut), doesn't mean it's not happening, I just haven't heard of it.
2024 Silverado ZR2 LZ0 Duramax
2021 Shock SS 1LE A10
www.youtube.com/@demonworksmotorsports
Anderson composites coupon code : Demon
DemonZL1 is offline   Reply With Quote
Old 06-15-2020, 06:55 PM   #22
Theseal
Drives: 19 zl1
True, i would probably keep similar spring rates. Are they published? But i like digressive shock valving gemerally, where the car soaks up high frequency bumps well and is compliant, but controls body roll at low piston speeds pretty well.
These are the opposite of that, and if your eyeballs are shaking so hard you cant see, you have too much high speed damping period.
Old 06-15-2020, 07:02 PM   #23
6spdhyperblue
Drives: 2SS 1LE
There’s a place in upstate NY that’s currently working on zr2 and 1LE rebuild kits. Not sure if that’s just seals or tuning as well. I called and they were in early r&d, that was around March
Old 06-15-2020, 07:35 PM   #24
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
I emailed multimatic US abotu the shocks.
if I hear back I'll post thier response.
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 06-15-2020, 08:55 PM   #25
cdb95z28
cdb95z28's Avatar
What happened to the DSSVs that it was decided there was a failure?
The Gen5 Z/28 DSSVs and the ZL1 1LE DSSVs both have a sintered brass vent on their body. This is needed because they are an insert type of damper. The insert will displace air as they move. Inside the damper, there are bushings that the insert rides on, Multimatic uses a clear to amber grease at these bushings. This grease will sometimes find its way to the brass vent. Some have complained that this points to a failure. This is normal. You can remove the vent and clean it with Brakleen and reinstall. I run the Z/28 DSSVs on my Gen5 SS 1LE. I have had the fronts apart to see how they work, and looking at GM's published literature on the ZLE DSSvs, they are similar in design.
See red arrow pointing to brass vent, yellow for bushing
"KEEP THE FAITH"-Fbodfather
Old 06-15-2020, 09:28 PM   #26
warren3537
warren3537's Avatar
Drives: 2019 Red Hot ZL1 1LE: 2012 RAM 2500
Originally Posted by 19Nasty1le View Post
Mine might have failed, might be the “boing” noise I was getting when hitting some bumps while turning
I have been getting the "Boing" (Front Pass Side) since I hit 850 on the odometer and now at 1K it seems to get worse, but as of this morning in the carport, I fired her up and no noise after going back and forth with the steering wheel, but when I take her out and drive around it will come back so who knows, well hopefully someone will.
warren3537 is offline   Reply With Quote
Old 06-15-2020, 09:31 PM   #27
ZRacerLE
ZRacerLE's Avatar
Drives: The DSSV Twins: ZR2 and ZLE A10
Why not have them replaced under warranty until it is up?
ZRacerLE is offline   Reply With Quote
Old 06-15-2020, 10:12 PM   #28
SCCAForums
SCCAForums's Avatar
Drives: Chevrolet Camaro, Ford Mustang
If you don't want the DSSV shocks, MCS are a great alternative.
2022 SS 1LE - Vivid Orange - SCCA CAM-C & Optima Ultimate Street Car GT
Katech, MSD, QA1, Hurst, Anderson Composites, ProParts USA Custom Suspension, Auto Addict USA, Forgeline Wheels, G-Loc Brakes, Nine Lives Racing, MTX Audio, Penske Rapid Repair, RacingBrake
SCCAForums is offline   Reply With Quote
