#15 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: like an old lady Join Date: Jun 2012
they are truck motors in stock form. look at a dyno graph, it’s very evident. even with car intake manifolds the power curve screams truck motor. huge, broad torque curve, tiny hp peak and then it’s immediately done.
#16 |
![]() ![]() ![]() Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
Why do they need different HPFPs and injectors? Improve idle quality on trucks with smaller following injectors?
#17 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro SS 1LE Join Date: Aug 2018
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler. 2018 Colorado zr2 - zr2 sport bar, showcase spare tire. 2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace. 2017 Corvette Grandsport (sold) - untouched. 2006 GTO (sold) - iat relocation, air box mod, monero side marker lights. |
#18 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL-1 Join Date: Feb 2009
They wanted something special for the Camaro 6 Gen. When you look at it the OEM headers are pretty darn good and sound great. They had more space to work with ( Corvette has the least.)
2012 Yukon XL Denali w/ 6.2 AWD |
#19 | ||||
![]() ![]() ![]() ![]() ![]() ![]() Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
So either Camaro is underrated so C7 has that slightly higher advertised BHP number, or Camaro drivetrain is less lossy than C7's. But yeah, the Vette's faster in a straight line due to aerodynamic, gearing, and weight advantages. Quote:
Granted, it has more to do with the tune and ignition timing, but I wonder if the exhaust manifold plays a part as well.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
#20 |
it doesn’t.
#21 |
I would expect the cast iron manifold and cat bolted to it (don't know if the vette has 4 total or just two), would light off pretty quick. The tube header will take a bit longer to light off the cat, especially all 4. ULEV dumps a lot of raw fuel down the exhaust to light the cat off.
#22 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
I think almost all GM vehicles now meet CARB requirements which means 4 cats total (2 primary and 2 secondary). GM used to get around this by marketing a 49 state vehicle and a California compliant vehicle. GM started to phase this out in 2009 to where they only market 1 vehicle that is 50 state certified.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
#23 |
Drives: 6 on the Flo' Super Sport Join Date: Jan 2011
Basically, but tuned for Tq. and better MPG. I think.
#24 | ||
Its kind of like the old ls1 days when the camaro was rated at 20 less hp but at the wheels made the same... and the ws6 ls1 was really the king of ls1s from the factory even though it wasn't rated as so by pontiac.
#25 |
The 4-2 -1 OE exhaust headers on the Camaro are wortth about 2-4 hp over the vette...
#26 |
#27 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
Yeah that was done more so for midrange boost to move the extra lbs, not peak numbers
#28 |
![]() Drives: Car Join Date: Aug 2013
I'm bumping this to the Top.
I'm considering replacing my LT1 in my camaro that is damaged beyond repair with the L86. From what I've read, all the internals are exactly the same, even down to the cam timings (https://www.hotrod.com/articles/clos...evy-lt-engine/). However, I have seen other posts mention that the oiling is different, but no one can provide any clarity on what exactly that means. Does the L86 share the same piston oil squirters as the LT1? Aside from all of the external items I can take off my broke LT1 and swap to the L86 (oil pan/valve covers/I have headers/intake/tb/etc...) here are the items i'd like to verify: 1) HPFP and Injectors are different between the L86 and LT1? 2) Same front and rear cover? 3) Same valley cover? 4) Stock LT1 tune should work? 5) When swapping motors, what do I need to keep in mind with the oiling? Are the oil galley's differently? 6) Does the L86 block share the same oil cooler provision as the LT1? Thanks for any tips! |
