Old 10-14-2020, 12:47 PM   #15
wytelightning
Drives: 2017 Camaro SS M6
i ended up going with the Stage 3 cam from Pray Performance. Just finished install last week. It sounds amazing and drives great. ill probably just plan on checking and replacing springs every year or so. i'm sure i will be in there for more upgrades soon anyways.
wytelightning is offline   Reply With Quote
Old 10-15-2020, 11:28 PM   #16
Nightfall ss1le
Nightfall ss1le's Avatar
Drives: 2020 A10 ZL1 1LE
Nice. I’m about to get an appointment setup for a stage 3 as well & most likely some GPI drop ins just to be safe. What heads, springs, lifters & valves did you go with? I’ve got everything else sorted out but I’m not sure on that stuff.. I’m a total noob when it comes to anything other than bolt-ons but I’m hoping I can get a setup that I don’t have to worry about replacing too often.
2020 ZLE Roto-Fab dry
2018 Camaro 2SS 1LE - 2" TSP catless headers, Pray Ported stock IM/TB, Rotofab dry, DSX FF kit, dyno tuned by Pray. SOLD
Nightfall ss1le is offline   Reply With Quote
Old 10-19-2020, 07:09 PM   #17
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
My cam has 4 degrees of overlap (@.050), the shaking and misfiring goes away once you past about 1000 rpms, so even when I raised my idle speed to around 850 or 900 rpms I still had slight stumble and surging when in gear. I feel like its worse when I try to raise the idle that high with it pushing and stuff, so I just went back to down to near stock idle speed and deal with the bucking and surging.
There are certain weather conditions were the idle will be a lot more stable almost to where it comes close to feeling stock for a few seconds.
I've tried doing a lot of things, and I've tried using a GDS scan tool (Chinese copy that never works) to play with timing and other stuff. I am also running E85 so that adds another variable.
I want to experiment more with forcing it to open loop and richening up the idle a little more to see if it helps the misfires. That is the only thing I know you can really do to try to help a big cam idle better.
cmitchell17 is offline   Reply With Quote
Old 12-20-2020, 12:05 PM   #18
Camaro grey
Drives: 20177 2ss
If I go with a stage 3 cam from texas speed and a 3200 stall will I need new heads to make this work so I do not bend the valves? Any info is greatly appreciated. Oh it’s going in a 2017 camaro ss 6.2L
Camaro grey is offline   Reply With Quote
Old 12-20-2020, 05:06 PM   #19
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
You say you are dealing with some bucking and surging, are you still running a stock converter? If so you might want to look into a bigger stall so that all will not be a problem anymore, instead of playing with the idle and fuel mixture. Might end up messing something up doing all that changing around.
1JEWLDSSRS is offline   Reply With Quote
Old 12-20-2020, 05:14 PM   #20
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
If you don't go with the biggest cam thy have, a stage 4 you should be alright. I run their stage 3 in my L99, 231/246@112LSA..614/641 lift. The stage 4 from what I hear you will need to flycut the valve reliefs in the piston tops. Also I ran a 3200 Precision stall for 3 years and it was not enough stall for this cam, I switched to a Circle D 5C single disc with a 4200 stall and man what a big difference it made!! She flashes up to 4800-5000 and stays there and just puls like a freight train!! The 3200 would flash to around 3600-3800 and had a dull spot until it got over 4000, then would take off, so I switched and much better. Good luck. Don't fear the stall!! Daily driveability is still nice and smooth.
Old 12-30-2020, 01:06 AM   #21
cmitchell17
Yes that's true, i would like to get a little higher stall with the cam I have. I just don't want to go to big since the 8L90 has eight gears, it's my opinion you could go too much stall given all the gear ratios available. I think with a 4L60 and 4L80 stalls help a lot more than they hurt given that they decrease drive line efficiency, but with 8 gear ratios the higher stall isn't needed as much. It would be nice to do the math or calcs to prove this though.
I guess if you look at the stall gm put in a 4L60 vs 8L90, i think they put a looser one in a 8L90, but I think that has to do more with the fact that they knew they were going to have the one in the 8L90 and 6L80 lock in all the gears past first anyway.
Are you saying a higher stall helped you get rid of the bucking and surging feeling during a rolling idle and during a lightly breaked idle?
Old 02-07-2022, 06:57 PM   #22
TimmyM55
TimmyM55's Avatar
Drives: 2018 Camaro 2SS
Originally Posted by RideZX6R View Post
in my experience with 5 different "big cam" vehicles.... Drivability is largely based on your TUNER and their ability, not the cam itself.
Anything anyone will sell you OTS these days will drive fine with a good tuner. Any custom spec'd cam will drive likely even better as it will be spec'd for your goals (one of which will likely be drivability with proper tuning)
But if the tune sucks, the driving will suck.
FWIW - my 1LE had a cam that was aggressive enough to need valve reliefs cut in the pistons... First tuner didn't have enough experience with GENV stuff (specific the more advanced TQ management) and the car drove... okayy. I had a more experienced shop re-tune it and not only did it pick up about 20whp, but it then drove like stock with a lumpy idle. Not exaggerating either, I could putter around a parking lot letting it idle in first with pretty much no issue. All in the tune man.
I currently am running a BTR stage 2 in an 18ss A8. I was wondering what’s considered “stock” idle. My idle is very choppy and rough, but I was told by the tuner that is normal. If it can be tuned to a near stock idle without shaking, I think it may be best to get someone else to take a look at it.
TimmyM55 is offline   Reply With Quote
Old 03-31-2023, 10:37 PM   #23
Blackmonba6Gen
BLUPRINT_1LE
Blackmonba6Gen's Avatar
Drives: 2022 Rapid Blue SS 1LE
This is what I would consider like a "stock" idle sound with cam setup.
https://youtu.be/csLPzspxCHk
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE
YT: BLUPRINT_1LE
Blackmonba6Gen is offline   Reply With Quote
cam, heads, pray
