Old 05-27-2020, 11:18 AM   #15
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
no just the front crank seal is good.
Old 05-27-2020, 01:40 PM   #16
Tim M
Tim M's Avatar
Drives: 2018 Camaro SS 1LE
Tim M is offline   Reply With Quote
Old 05-27-2020, 04:12 PM   #17
Staximus
Drives: 2019 Camaro 2SS
My local auto store has that part so it worked out. Will put seal in and wait for the Mighty Mouse venter before I go anywhere near above 2500rpm. Should I throw the car on the dyno to double make sure the procharger can tune is good? I talked to them today and they still stand by there bulletproof tune. Or as soon as I get the can and seal on I should be good to go? Thank you.
Staximus is offline   Reply With Quote
Old 05-27-2020, 05:52 PM   #18
Staximus
Used thst GM part number and got this, want to confirm it’s the right one. Thank you!
Old 05-29-2020, 05:35 PM   #19
Staximus
Another question guys. Another builder here locally to me said there might’ve been a chance that the balancer was spinning, causing the seal to brake? And I would need a new crankshaft? Any thought on that?
Old 05-29-2020, 06:07 PM   #20
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Believe the factory crank/balancer are keyed, so your local builder is wrong if I’m correct.
Old 05-29-2020, 08:58 PM   #21
KingLT1
KingLT1's Avatar
Josh is correct. The Factory balancer is key'd which is how Procharger gets away with using the cam lock pulley setup.
