Old 05-21-2020, 06:21 AM   #15
mrgoodbytes
mrgoodbytes's Avatar
Drives: '18 2SS/EU (+Recaros) M6 Red Hot
I am changing mine today. I just started noticing the groan when the car has been parked outside. I normally park inside a heated garage which is 20c degrees all year round, but I heard it the first few turns after the car was parked outside for 8 hours in 10c.
The car has 22K km and I have done at least 6 engine oil changes so far, so it is about damn time.
mrgoodbytes is offline   Reply With Quote
Old 05-21-2020, 06:59 AM   #16
dmcmahan60
dmcmahan60's Avatar
Drives: 2017 SS
Originally Posted by JCunningham View Post
im not arguing with anyone. its a fact. Thats the problem with forums and why pros dont get on them. People talking about stuff they know nothing about. You can tell someone the answer but someone who wants to be cheap will argue to justify saving $20. Call a pro or pull the drain plug and see the metal and black oil. Gears need to break in on any car. Q the keyboard warriors.
This times 1000
dmcmahan60 is offline   Reply With Quote
Old 05-21-2020, 07:08 AM   #17
Yellow Beast
TD
Yellow Beast's Avatar
Drives: 2017 2SS, 2014 Mercedes C300
I ordered 2 quarts from GM. Amazon also has it. Here are the links.
https://www.gmpartsdirect.com/oem-parts/gm-oil-88862624
https://www.amazon.com/Genuine-GM-88...0059252&sr=8-3
Yellow Beast is offline   Reply With Quote
Old 05-21-2020, 07:10 AM   #18
dviper42
dviper42's Avatar
Drives: Man
Send a message via ICQ to dviper42 Send a message via AIM to dviper42 Send a message via Yahoo to dviper42 Send a message via Skype™ to dviper42
Talking 2016 SS CAMARO A8 PP NAV YELLOW
Changed mine at 1500 miles only DD 55 miles round trip 5days a week. Never made any noise. I will do it again at 50000 now have 42000.
dviper42 is offline   Reply With Quote
Old 05-21-2020, 08:38 AM   #19
dpevans
Drives: 2024 Riverside Blue 2SS 1LE
Do it, sooner the better. Mine looked terrible and you could feel the grit in the fluid on first change at 10k, I did it again at 20k and it looked better and it's not that hard to do.
dpevans is offline   Reply With Quote
Old 05-21-2020, 10:15 AM   #20
900RFWN
900RFWN's Avatar
Drives: ‘18 ZL1 1LE
I had the diff fluid changed on the drive home from the dealer which was at about the 1100 mile mark. Around 5000 miles later it started groaning and I had the dealer perform the TSB. They flushed it twice and it’s been good. I’ll be doing it myself from now on but getting them to do it at least once for documentation purposes is good. Especially if it’s groaning and under warranty still.
Moral of the story, these diffs are expensive. I’m not going to let one go because I’m lazy or cheap.
900RFWN is offline   Reply With Quote
Old 05-21-2020, 10:16 AM   #21
driven2exceSS
driven2exceSS's Avatar
Drives: 2016 2SS BLK A8 Vert
A wise decision
driven2exceSS is offline   Reply With Quote
Old 05-21-2020, 11:40 AM   #22
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
I am thinking about doing mine when I install the splash guards. Probably looking at next weekend.
Just need to borrow the jack and jack stands again.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 05-23-2020, 08:21 PM   #23
Yellow Beast
TD
Changed my differential fluid today. The plug had build up and you could see some silver speckles in the sun. I'll drain it again in 2000 miles.
Old 05-23-2020, 08:38 PM   #24
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
Was it about a little more then 1 quart?
2016 1LT v6
- Totaled
Happiness: Infinite
Old 05-23-2020, 09:23 PM   #25
Yellow Beast
TD
Yes it took about 1.2 quarts. I drove it before I changed it to thin it out and get most of the gear oil out.
Old 05-23-2020, 10:47 PM   #26
supersportss
Drives: 2019 SS
500 then again at 1000
Ditto.
supersportss is offline   Reply With Quote
Old 05-23-2020, 11:33 PM   #27
Bumbleboy92
Long hauler
Thanks, I had one quart in shipment so just placed order on another!
2016 1LT v6
- Totaled
Happiness: Infinite
Old 05-23-2020, 11:52 PM   #28
L78toLT1
L78toLT1's Avatar
I've changed mine three times. First time at 6k miles, then after every two track days.
On all three changes, the fluid that i drained out looked every bit as good as the new stuff i poured back in.
Baby Blue
