Old 08-06-2020, 07:27 PM   #15
oldman
Drives: SS 6 speed of course
Originally Posted by ZeroZeta View Post
Everything that was said previously regarding running without a filter for street is a valid concern and I am sure some will say the risk is worth it to possibly pick up a few extra lbs of boost.
How is no filter going to add even a single lb of boost? This is a centri supercharger. Boost is more a measurement of engine restriction vs wheel flow (which is directly related to wheel speed). Given any reasonable restriction in the intake, the ONLY thing a better flowing intake will do is allow the centri to make the SAME boost with a little less HP drag on the engine PERIOD. How much HP will be saved? Unmeasurable.
I may entertain the option of running a filter directly on the blower - I have seen a few run that set up but no clue if they actually lost flow from not having the pipe with the curve.
A pancake filter like I ran on my Challenger could help just a tad:
https://www.edelbrock.com/pro-flo-un...let-43610.html
https://shop.advanceautoparts.com/p/...4&gclsrc=aw.ds
That said the only help is a slight bit less HP needed to drive the centri. Boost is directly related to engine restriction and blower pulley size on a centri PERIOD.
Old 08-13-2020, 06:35 PM   #16
greybst
Drives: 2016 2SS Nightfall Grey
ok...so hear it is... picked up 60 RWHP using a bellmouth...the position of the intake protects the procharger....I was a Gas Turnine tech for 26 years...never had any issue with damage....unless i leave a bunch of bolts and remove all protecive crap there is no worries about damage...as for the heat, simple fix...just use some heat shield plates over the headers.
2016 | 2SS Nightfall Grey | Procharger F-1A-94 Street race stage II | Callies forged crank and rods| Weisco Pistons | BTR Cam and head Package | Procharger intake manifold| secondary fuel system |nitrious |custom interchiller in trunk | Detroit speed/ JCI coilovers and bracing | ATAK exhaust | MRR Wheels | 305/285 Perelli's | Black bowties | Dark GM Tails and 3rd Brake Light | Diode Dynanics painted Side Markers | ACS Hood | C-7 Ground Effects | CF OEM Wing.
greybst is offline   Reply With Quote
Old 08-13-2020, 07:53 PM   #17
oldman
Here, a completely optimized full race set yielded less than 1 PSI of boost at the end of 1/8 mile.
https://www.dragzine.com/tech-storie...uth-air-inlet/
A pulley change of .15 to .25 will yield the same boost and need say 3 to 6 HP to drive. As I have already said, the yield is NOTHING on a street engine that is octane limited.
So your saying you tossed a bell-mouth on and saw 60 HP which is bout 3 to 4 PSI of boost increase.... do tell?
From this article and this is a system that has an intake free and clear of any stuff (not like a 6 gen install). 2PSI on transbrake, actually pretty impressive, (don't know how much RPM and throttle setting is used with a race transbrake) just don't think it is repeatable in something that fits under the hood. Even then the boost can be achieved by pulley change, a street engine is octane limited. Now if the discussion is should I run a bell-mouth on my race car with F1, it would seem so and the OP has a F1, I'll grant that. Just don't know how effective it would be at the current placement withing the engine compartment.
https://www.fordmuscle.com/features/...-both-engines/
