Old 05-15-2020, 11:54 PM   #15
Tim M
Tim M's Avatar
Drives: 2018 Camaro SS 1LE
I'd suggest laying a head gasket across it and see where the conflict is. Not familiar with LT gaskets, but many are a good bit larger than the bore (to account for boring, etc).
It is a critical area as the head gasket 'fire ring' passes invicinity...it seals off all the combustion pressure between the head and block. Really a bad place to have an imperfection.
You should certainly try something as decking/replacing the block is the worst case scenario.
Tim M is offline   Reply With Quote
Old 05-16-2020, 07:14 PM   #16
DC5
Drives: 2019 Chevrolet Camaro SS 1LE
Time to tell dad to open his checkbook . . .
DC5 is offline   Reply With Quote
Old 05-17-2020, 12:14 PM   #17
NicKey
NicKey's Avatar
Drives: Nickey Super Camaro
That must be a heavy flashlight.
NicKey is offline   Reply With Quote
Old 05-18-2020, 02:09 PM   #18
MackSteelPrivateEye
I would say fill it with a drop of high temp epoxy then sand it down level just to be safe.
Old 05-18-2020, 02:21 PM   #19
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
Originally Posted by Rcamacho22 View Post
Why do you believe it’s gonna fail?
The high pressure and heat will probably blow out and burn any epoxy. I very highly recommend you show this to a engine builder.
Old 05-18-2020, 02:47 PM   #20
MackSteelPrivateEye
Upon further review...I don't think its a problem. Look at how the Nick is. Its only about a 16th of an inch long and fades away back into the flat undamaged surface. So with a properly sealed gasket where can it leak too? Not like the Nick runs completely across the surface to the next Cyl. I say seal it put the gasket on and torque it to specs. You won't have any issues.
Old 05-18-2020, 05:16 PM   #21
SanDMaN2091
SanDMaN2091's Avatar
Drives: 2016 Camaro SS A8 NPP
Find a welder
3 rings of tig weld (low amp), straight edge, and a dremel? I'm not a pro welder but it seems the only true fix am I right?
DMS Flex Fuel-E85
HPTuners Ngauge
Roto Fab CAI,
LPE Ported/Polished 95mm LT5Throttle Body,
PRAY Ported MSD Intake Manifold,
SP Coated TSP 1 7/8" Catlless Longtubes
Hooker BlackHeart Cat-Back,
Mishimoto Catch Can (Which always has some nasty in it)
Instagram@Weapon_6
SanDMaN2091 is offline   Reply With Quote
Old 05-18-2020, 05:19 PM   #22
JCunningham
Drives: 2017 2SS M6
the block should be decked on both sides is the only true fix. welding would probably require the cylinder to be rebored. The heat might warp it.
