#15 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
Well, the tires ive corded on my 1le did so on the inside. Ditto TheRealJa if i recall his pix properly on his SS. Ditto a friend with a ZL1 running G3Rs. A tire cording on the outside and this quickly is pretty strange imo. Anyway, curious to find out how often Sean swaps the fronts to get 3 days outta them. Cheers!
#16 | |
![]() ![]() ![]() ![]() Drives: 1LEs Join Date: May 2009
https://www.camaro6.com/forums/showp...postcount=1132 I’ve had the links in since very shortly after getting the car. I’ve hard corded more on the inside than outside at ~2.76-2.78 front if I only rotate side to side and don’t flip the fronts on the rim (ZL1 1LE wheels). This was my last front wore out with final HC’s [8x 30-minutes EACH LF and RF position] and street round trips [4x 180 miles] marked. I was lazy and did not trailer nor change tires at the track for that set nor did I flip the fronts on the rims. Last edited by RUQWIKR; 05-15-2020 at 09:28 PM. |
#17 |
![]() Drives: 2018 ZLE Join Date: Jun 2019
The SC3R can last 3 days even with hard driving you just have to manage temps. If your running a hpde and 20-30 minute sessions recommend just 1 cool down lap in the niddle and will help significantly. Also zero toe I found to be crucial! Good insight on RRs- always been a hoosier fan myself!
#18 |
![]() ![]() ![]() ![]() Drives: ZL1 1LE Join Date: Oct 2016
I don't think the innerwear issue on the ZLE/G3R's is related to tire temps, at least in my own experiences. Tire temps have never shown to be out of control, oddly, even on the innermost portion of the tire that cords.
What have you experienced/tested to show temps play a role? I would love to get more heat cycles out of the G3R's! Even playing with zero toe or +1/16th, I've maxed about 7-8 heat cycles.
#19 | |
Not sure how Cem ended up with a tire that looks completely brutalized. Weird he would not have noticed it starting to go until 5 runs later. Unless something extraordinary happened on the last run? Like the camber went? No idea, so hope he chimes in and hopefully sheds more light here. PS I assume we all check our tires after each run as a matter of regular safety protocol. Besides any trouble on the outside left is really easy to spot. So, again: i am baffled. |
#20 |
https://www.camaro6.com/forums/showt...484731&page=81
I am adding this thread as relative to G3R. See post #1130 onwards incl pix. |
#21 | |
![]() ![]() ![]() ![]() ![]() Drives: 2013 C6Z06 Join Date: Nov 2016
However with all these conversations about dynamic toe change and dragging the inside wheel through turns, I really don't know if the inside cording is from street miles or this
#22 |
I don’t street drive my car at all and cord within 7 sessions.(on the inside)
#23 |
I have never corded a single tire on the outside. Ever.
Street driving loads are nothing in comparison to track loads. Unless a toe spec is way off, even a soft tire will survive DD for thousands of miles, even with track camber. Especially a modest one. And especially with zero toe. Anyhow, looking at that pic of LF, I'd suggest that tire had undergone some physical trauma. Like a sharp curb, etc. There seems to be a whole outside strip of rubber gone. As if something cut it off. At least in my eyes looking at the pic. If it happened to me i would not consider it normal under any circumstances. High degree of graining may also offer a hint here. Anyhow, not my problem
#24 | |
It really seems like Cem overheated that outside edge and it just delaminated. Cem what does the inside of the RF look like? |
#25 | |
#26 | |
Shifts under load
Drives: 2020 Camaro 1SS 1LE rally green Join Date: Apr 2017
HPDE - southeast - JTI- solo, PCA- blue. 22 Suzuki GSX-S 1000GT blue |
#27 |
![]() ![]() ![]() ![]() ![]() Drives: Grandad's C2 L89 Join Date: May 2017
Great write up glamcem, thanks.
Thanks to all for posting follow up opinions/trials. Following.
2018 ZL1 1LE sw/PDR
#28 |
![]() Drives: Camaro ZL1 Join Date: Jan 2018
I agree with TrackClub, RUQWIKR's tire points towards a tire failure and should not happen. I would take it back to Goodyear and request a replacement.
