Old 06-07-2020, 11:21 PM   #15
Originally Posted by Fire260 View Post
Do you know what the updates are then? I have had two OTA since I bought the car almost one year ago and I thought it was software updates.Thanks
I double-checked and the 2019 can already update everything, I was mistakenly thinking about Cadillac's 2020 changes, sorry. You guys should be good.
My 2018 also has some update functionality over wifi, but it's limited, updating the infotainment software itself requires a dealer visit.
Old 06-08-2020, 12:04 AM   #16
Fire260
Fire260's Avatar
Drives: 2019 Camaro LT1
Cool thanks for clarifying it.
Saying THANKS don’t cost a dime so hand it out freely!
Fire260 is offline   Reply With Quote
Old 06-08-2020, 03:48 PM   #17
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
Well, I am getting my car back today and I will see what setting affects it, possibly.
If that doesn't work, I will mention it when I bring the car back in for the PDR repair. The g-meter is off by 0.07G by one side; they tried a relearn and it didn't work, so they said they will have to replace one of the parts.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 06-08-2020, 05:08 PM   #18
RLNTLSS
INTSAGRAM: Failwish
RLNTLSS's Avatar
Drives: 2019 /2SS LT1
I have had a few OTA UPDATES.. IM 2019 A10
2019/LT1 2SS
RLNTLSS is offline   Reply With Quote
Old 06-12-2020, 09:19 AM   #19
Fire260
Fire260's Avatar
So did you figure out anything on the locks?
Old 06-12-2020, 11:05 AM   #20
UnknownJinX
Nah, I tried to adjust different settings, even the ones that are completely unrelated. Nothing I did made it appear, ever.
I will make sure I ask about it when I go in for the PDR repair.
Current:
Past:
Old 06-12-2020, 09:39 PM   #21
Keep us updated on the outcome, I'm very curious to hear what it was
Old 06-12-2020, 10:00 PM   #22
Fire260
Fire260's Avatar
+1, Thanks
Old 06-13-2020, 07:13 AM   #23
ember1205
Hot Camaro
ember1205's Avatar
Here's what's in the manual for my 2020:
Page 20 states:
Automatic Door Locks
When the doors are closed, the ignition is on, and the shift lever is moved out of P (Park) for automatic transmissions, or if the vehicle speed is above 13km/h (8 mph) for manual transmissions, the doors will lock.
<directions to unlock doors>
Automatic door locking cannot be disabled. Automatic door unlocking can be enabled through vehicle personalization. See Vehicle Personalization - 124.
On Page 124 (127, actually, as 124 is the start of the section):
Auto Door Unlock
This allows selection of which of the doors will automatically unlock when the vehicle is shifted into P (Park) with an automatic transmission or when the vehicle is turned off with a manual transmission
Select Off, All Doors, or Driver Door.
I checked the menus on mine and everything is present as described in the manual, and I have a 6MT 2SS. I definitely can not see this being a trim level item and would suspect that the software needs to be re-flashed at a minimum. I have read of some owners have odd issues with their cars due to this car having a lot of computer-controlled areas and being overly sensitive to voltage values from the battery. Lots of conversations about keeping the car tied to a battery tender all of the time to prevent weirdness... ???
Old 06-13-2020, 10:24 AM   #24
Page 20 states:
Auto Door Unlock
This is exactly how it works on my 2018 as well, the wording in the manual is the same to the letter, the same menus are present and every option works as designed.
I think UnknownJinX's infotainment has some software glitch that the dealership will hopefully confirm and fix.
Old 06-13-2020, 12:18 PM   #25
NYJets12
NYJets12's Avatar
Drives: 2018 1LT Camaro
Page 20 states:
Auto Door Unlock
Looks like that’s the answer if you set it to off that should mean your doors will not unlock. They will all stay locked.
NYJets12 is offline   Reply With Quote
Old 06-22-2020, 05:02 PM   #26
UnknownJinX
So I was informed by the dealer that it's because I have the navigation(RPO code IOT) and it's a functionality exclusive to the RPO code IO6(8" head unit w/o the navigation). They run different firmware and so it's not available to me.
Dunno if this is the actual reason, but that's what I have been told.
Current:
Past:
Old 06-22-2020, 10:37 PM   #27
Well if that's true, it's one weird change for 2019, because I have navigation on my 2018 and this lock option works on mine...
Also, IO6 is a 2016-2018 infotainment RPO name, specifically the one I have, and the 8" head unit w/o nav went by IOS in 2019, so I have some doubts about whether this information is correct. It also makes zero sense to take away a valuable feature from a higher spec infotainment unit, but then that would not be fully unexpected from GM.
Hopefully someone else with a 2019 + navigation or a dealer/aftermarket vendor that has more information can chime in to help you. Could this be a Canada-specific change perhaps?
Old 06-23-2020, 01:42 AM   #28
UnknownJinX
16-18 run on MyLink while 19+ run on Infotainment 3, so they are different systems with different software and possibly hardware as well.
I read the comments on the papers they gave me, which said that a "dummy vehicle" with IO6 RPO has the auto door unlock options. The guys at the shop mentioned that they have a few 18 Crush Hot Wheels lying around, so they could have tested it on that.
But yeah, if someone with a 19+ w/navigation(so 3LT or 2SS/ZL1 with it optioned) can chime in, that could help me see if the dealer's explanation is true.
And yes, I agree with you that I wouldn't be surprised if this is just a mistake in the firmware for the IOT...
Current:
Past:
