Old 05-02-2020, 06:14 PM   #15
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
What happens if you run the 295 25 19 that matches?
Does it mess with the computer?
I've been running the 345 toyos on an 11 inch rim with no problems it just looks funny that the tire bulges over the rim and isnt lined perfectly like the 325 does I'm the pic.
I'm sure in my case drop pressure and I get better traction off the line and some side wall give..
Running normal pressure I haven't seen any awkward feeling in high speed turns..
I just bought 2 rear 19x12s OEM wheels.. how does the 355 look on the sidewall compared to the rim?
Also I didn't have to move the harness with 19x11 et 38mm
Wondering if I will om the 19x12s?
Old 05-02-2020, 07:18 PM   #16
SpeedLimit
Drives: 2019 F150
Originally Posted by SFV1LE View Post
I run PSC2s in 315/30/19-F 345/30/19-R on track and tested these in the most grueling G forces of the banking at ACS in Fontana. They fit no rubbing, or at least none that cuts the tires.
345 PSC2 looks badass on the ZLE, this may be the only tire that looks more badass :-)
I used to think 285/30/18s on all corners looked wide on my Evo X.
This is some damn good information you're posting.......
Is this photo 315/30/19 - 345/30/19 ??
SpeedLimit is offline   Reply With Quote
Old 05-02-2020, 08:09 PM   #17
2018$S1le
2018$S1le's Avatar
Drives: '19 ZL1 1LE Summit White M6, PDR
Yeah it’s funny how wide tires vary in how they look on different cars. For example I had 315s on my old 94 z28 and it looked good but the same tire looked massive on a c4 Corvette. And thanks, I couldn’t agree with you more lol!
2018$S1le is offline   Reply With Quote
Old 05-02-2020, 08:24 PM   #18
2018$S1le
2018$S1le's Avatar
Fortunately Kuhmo now makes the V720 in 305/30-19. Mine will be here Tuesday. I assume running the 295/25-19 would potentially mess with the computers head lol. But that’s not a problem now. I will go grab a pic of the sidewall.
Old 05-02-2020, 08:26 PM   #19
2018$S1le
2018$S1le's Avatar
I would say move your wiring harness. It’s super easy and requires only 30 minutes and 2-3 zip ties.
Old 05-02-2020, 08:47 PM   #20
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
I'll move the harness.. and thank you awaiting pics.
Old 05-02-2020, 08:51 PM   #21
cirpower
Drives: Camaro ZL1
This could be great. Thanks for testing it. I am still looking for a somewhat budget friendly track day tire for my apex wheels in the 1LE dimensions (I have a normal ZL1, not a 1LE). How much is this set and where did you order?
cirpower is offline   Reply With Quote
Old 05-02-2020, 09:07 PM   #22
2018$S1le
2018$S1le's Avatar
eBay is where I bought mine. Normal tire stores can’t seem to get them without a hefty mark up. Normal price on rears seems to hover around $375 each but then they went on sale for $315 and I jumped on it. The fronts were $242 each from a different seller. One store got close to matching that but I went eBay again to save a few bucks.
Old 05-03-2020, 03:49 PM   #23
cirpower
Drives: Camaro ZL1
Thank you! Is there any way the 305-30-19 will fit the rear as well? They might be too narrow for a 12 inch wide wheel? cheers
Old 05-03-2020, 09:15 PM   #24
SpeedLimit
Drives: 2019 F150
Looking at the photos, this tire looks about right for the wheel size if you drive on public roads and park around town a lot.
I like the accurate driving feel of stretched tires. With that said, If I could avoid curb rash I would choose avoid wheel damage every time.
Old 05-04-2020, 09:47 AM   #25
2018$S1le
2018$S1le's Avatar
Just theorizing here, but there's only 1 inch difference between the front and rear rim in width. You can probably get the 305 on the rear wheel but as mentioned above it'll look a bit stretched.
Old 05-04-2020, 10:16 AM   #26
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
I really like these as a track tire option for the price and performance, I dont think 325 3R will fit in front on ZLE.
You can either run 305 3R, or 315 Hoosier R7 or 315 PSC2. I'd try the PSC2 first because the idea is to have a set of 4 that wears better than 3R, and nothing wears faster on track than 3Rs on the front of a ZL1.
People have run 335 square Rivals on an SS on track. A 325 G3R can fit a ZLE for sure with the right spacer.
Originally Posted by 2018$S1le View Post
Yeah I doubt the 325 would fit up front too. It’s one thing to add width in the back where the wheel only moves up and down, but up front there’s also the turning to consider. I will have to pass on being the crash test dummy for that one lol. Here’s a good pic of the new rears.
See above, but I don't blame you for not wanting to be the tester.
Completely different tread compound though. The non-ACR V720 is an autocross only compound that won't hold up to tracking. Not an issue if you don't track.
No one knows on the ACR front tire, but just like I told you, everyone thinks the huge diameter difference will cause a problem. You are going to have to be the first one to try it on a Camaro if you really want to know. I just bought 4 of the front tires to run square, like Coby is running on his SS1LE in Gridlife time attack. I'd love to run the ACR rear tire, but I'm not spending the money for another set of rims with at least a 12" wide rear right now.
Old 05-04-2020, 05:03 PM   #27
2018$S1le
2018$S1le's Avatar
Yeah I noticed the 305/30-19 didn’t have the ACR designation so I did some digging and found what you said. These are just street tires for me though. I plan to get a 2nd set of wheels and remount the GY’s.
Old 05-05-2020, 12:12 AM   #28
Jason18ZL1LE
Drives: 2018 ZL1 1LE
I recall you saying that the 345s were equal to the width of the 325 SC3R.. what was your overall opinion on the PSC2 in 345 vs the SC3R in 325s? I was there the same day as you but with the factory sizing PSC2 and sliding all over the place. Hated the PSC2 with my power levels in the factory sizing
2018 ZL1 1LE - Summit White
529whp Baseline / 760whp 762tq
ARH Ceramic Coated LTH 1 7/8" \ ATI 15% Lower \ RotoFab Big Gulp \ Katech 103mm TB \ Ported Blower \ DSX Fuel System \ Flex Fuel E85 \ Custom Cam \ Dual Springs \ Corsa Exhaust \ Prospeed Heat Exchanger \ Cordes Big3\ C&R Racing Radiator \ LS3 Stat housing \ 160* Thermostat \ NX Lid
Jason18ZL1LE is offline   Reply With Quote
