Old 04-29-2020, 07:23 AM   #15
laynlo15
Drives: 2022 Lt1 A10
Wow, 900 at Costco.
Old 04-29-2020, 07:55 AM   #16
Stevezx900
Stevezx900's Avatar
Drives: Buick Grand National, BMW M5
Who is brave enough to try this on a four post lift?
I seen on YouTube that is possible!
Stevezx900 is offline   Reply With Quote
Old 04-29-2020, 07:58 AM   #17
Stevezx900
Stevezx900's Avatar
See example.
Old 04-29-2020, 08:09 AM   #18
Stevezx900
Stevezx900's Avatar
Wow, 900 at Costco.
I just Costco’s website. It’s $1,199 with my zip code.
Old 04-29-2020, 08:29 AM   #19
Alain
Alain's Avatar
Originally Posted by 1hprush View Post
Alain- What model did you get? Did you get the 110V? Did you have too modify the unit to fit your car? Thx.
I got the 7,000 lbs extended version that you can plug into a regular house hold socket (I think that’s the 110V unit).
I didn’t have to modify mine at all.
I got the 7,000 pound version in case someday I need to lift a big SUV or Pickup.
I don’t remember what the extenders look like or how they mount to the lift. But be warned, the Quickjack barely fits under the rocker panels of my Zl1 1LE in the front.
If those extenders add any height to the Quickjack when installed then you’ll have to drive your car up on wooden blocks to be able to slide the Quickjack under it. Adding another step to the process, not the end of the world though.
2018 ZL1 1LE/Red hot
Old 04-29-2020, 08:30 AM   #20
Alain
Alain's Avatar
Originally Posted by Stevezx900 View Post
See example.
There’s no danger in doing this on that type of 4 post lift. The QuickJacks are more than stable on that platform.
Old 04-29-2020, 08:34 AM   #21
Techdude99
Techdude99's Avatar
Drives: 2019 Chevy Camaro ZL1 1LE
This is from several months ago. Setup an alert on Slickdeals to get notified on the price drops.
Techdude99 is offline   Reply With Quote
Old 04-29-2020, 10:20 AM   #22
20Bluezl1
$800 that is a great deal. Hopefully I can find that deal.
Old 04-29-2020, 12:43 PM   #23
v8
v8's Avatar
Drives: 19 Z06
I have the 5000 and use it all the time, I have used the 5000 to lift my wife's MDX and my Toyota Tacoma and it was fine. I would have bought the 7000, but I picked up a 5000 from Costco about a year ago on sale and no regrets
Gone but not forgotten:
1974 Corvette Stingray 454
1986 Z28
2009 Mustang GT convertible
2012 45th 2SS Vert
2013 ZL1 M6
2014 Zl1 M6
2014 GT500
2016 Challenger Hellcat M6
www.youtube.com/c/garageking
v8 is offline   Reply With Quote
Old 04-29-2020, 01:06 PM   #24
Ebbsnflows
Drives: 2018 Camaro ZL1-1LE
I use the 5000SLX on my 18 ZLE as well. No issues whatsoever.
2018 Camaro ZL1/1LE
Ebbsnflows is offline   Reply With Quote
Old 04-29-2020, 01:27 PM   #25
Silveradoss573
Drives: Camaro 1LE
Either the 5000ext or 7000ext is near perfect length for these cars. If you buy the standard 5000 or 7000 and add the optional extenders, you'll loose 1-1.5" from the lift to bottom of car. I have the 5000ext and bought it directly from quickjack. Ended up getting like $200 off using the active promotion at the time. I used quickjacks measuring guide so I knew whatever I ordered would not only work properly, but work and be as safe as possible.
https://www.quickjack.com/support/measuring-guide/
Silveradoss573 is offline   Reply With Quote
Old 05-02-2020, 08:38 AM   #26
Chris 2018 ZL1 A10
Drives: Chevy Camaro ZL1
Hi fellas,
I’m considering buying this lift. I just purchased (4) 3” Jack MagPads from ZL1 AddOns for when I take the car to my dealer.
1. Can the MagPads be used with the QuickJack and are extensions still recommended?
2. Is there sufficient clearance to park my non-1LE over the QuickJack for space constraints?
3. With a car on this lift, are there any further safety recommendations to consider?
Thank you,
Chris
Chris 2018 ZL1 A10 is offline   Reply With Quote
Old 05-02-2020, 04:00 PM   #27
Alain
Alain's Avatar
Originally Posted by Chris 2018 ZL1 A10 View Post
Hi fellas,
Thank you,
Chris
1- yes the Mag pads will be usable with the quick jacks. If you get their permanent lift point pads, they will work too (those are the ones I have on my car).
2- if my ZL1 1LE fit over the Quickjack, your non 1LE should with mo problems. You can always just get 4 pieces of wood to drive on to to give you an extra inch or two of clearance (I have to do this in the front with my Shelby).
3- I don’t think there is anything else you’ll need to be safe under these things. You can always position jacks under the car in case the QuickJacks fail somehow.
If you watch their video you’ll see once they lock in position they are not going anywhere, even if the hydraulic cylinders fail. As long as that locking bar and the piece of welded metal they secure lock into are good, you have nothing to worry about.
Old 05-02-2020, 04:04 PM   #28
Techdude99
Techdude99's Avatar
Agreed. Good info.
