#15 |
@Blackmamba_1LE
Drives: 2017 1LE Join Date: Jun 2017
Actually I saw on FB a 2017 LT highly modified and noticed it had a double din radio where the main screen is usually at. I'll see if i can find it
Florida High Performance: H/C Whipple LME 377 900WHP
#16 |
![]() Drives: 2020 LT1 Join Date: Nov 2019
#17 |
![]() Drives: Camaro ZL1 Join Date: Apr 2019
If you can carplay/android auto to the head unit, I'm really struggling to see why you'd want to change it?
Made in the USA. Refined in Great Britain - insta: zl1uk
Velossa intake, Rotofab, Mamo TB, Custom ported NX Lid & Jokerz Full tilt ported LT4 charger, 3 port CoolingMist Meth injection - ATI 15% lower pulley, E2X CC, TSP ceramic coated longtubes, de-cat and Borla 60608 to NPP box, JRE tune, BMR rear control & trailing arms, lock-out kit, lowering springs and front strut brace, Custom carbon trim interior, Xpel ultimate front PPF and Prestige window tint with Chameleon Windscreen tint...ever evolving... |
#18 | |
![]() Drives: 2018 Camaro ZL1 Join Date: Feb 2011
Sent from my SM-G960U using Tapatalk
AudioControl 2x LC6.1200, LC1.1500, Audison Bit One Virtuoso, Bit Play HD, Frogs, NavTV M650, JLA 12W6
#19 |
![]() ![]() ![]() ![]() ![]() Drives: Chevrolet SS 1LE Join Date: Oct 2019
Wouldn't the big advantage be in getting a new head unit that could output a digital signal to a DSP unit? That should give better sound quality than taking the speaker-level outputs from the stock radio control unit. I don't think there's an option for pulling the digital stream from the stock unit, correct?
Matt Miller
2020 SS 1LE |
#20 | |
#21 |
Exactly this. I have the GM unit and an Audison Bit One ready to take the signal.
#22 | |
#23 |
![]() Drives: Chevy Camaro Join Date: Apr 2020
The stock systems in these cars suck and distort very easily. Aftermarket head units will give you way more control, and a lot cleaner signal to your your amps vs adding devices to convert the crappy stock radio signal over to something stable the amps can use. The down fall is they are expensive and installing them will take some know how. 95% of users this above what they need or want. Think of it of having a audio control lc7i in your head unit and you can control it right from the drivers seat without the need of installing separate remote controls or having to make adjustments of a processor in the trunk.
#24 |
Bump for hope!
#25 |
![]() Drives: Camaro Fifty Join Date: Sep 2018
I found some alternatives here:
https://m.de.aliexpress.com/item/400...bilesitedetail https://m.de.aliexpress.com/item/400...0Q90.jpg_.webp https://m.de.aliexpress.com/item/400...0Q90.jpg_.webp I guess it's always the same part from different sellers. Who wants to be the first to find out if it works... |
#26 | |
Drives: Fast if no one's looking Join Date: Aug 2019
#27 | |
Long hauler
Those AliExpress links don't help either lmao But for you guys that know more, I got the original site of those without the AliExpress stuff. https://www.lsailt.com/product/298.html
2016 1LT v6 - Totaled Happiness: Infinite |
#28 |
Thank you for the link.
I'm pretty statisfied with the factory system and don't want to try out this cheap stuff. But if there is someone who absolutely wants to replace the factory system have fun and good luck. |
