Old 04-25-2020, 09:06 AM   #15
Originally Posted by getchapull View Post
Thanks.
I wonder how much a 3" extension will reduce a 150 lb torque value?
My memories of middle school physics are fading fast, but why would it change the torque value that the wrench reads? Extensions help you, that is, your muscles by allowing the exact same torque via the application of less force over a greater distance. There is no change to whatever torque value the wrench reads at the lug.
Old 04-26-2020, 03:35 PM   #16
ohsmily
Drives: '19 ZL1 1LE A10 ShadowGrayMetallic
Thanks.
If you're referring to an extension on the socket, the answer is zero, i.e. not at all.
ohsmily is offline   Reply With Quote
Old 05-10-2020, 04:03 PM   #17
TRZ06
TRZ06's Avatar
Drives: 22' Porsche PDK GT4
Originally Posted by TRZ06 View Post
Common issue. Mine did it when new. Has to do with contaminates getting in-between the wheel and wheel hub.
Solution is for them to take off the wheels and clean both surfaces.
Mine went away after that fix and after 20K miles is just starting to come back, will have them address it with the next oil change interval.
UPDATE: After dealer cleaned the hub and wheels, both sides are again silent.
Current:
Previous:
09' C6 Z06
08' E90 M3
06' 335i (KW V2 Coilovers)
03' C5 Z06
Old 05-12-2020, 10:09 PM   #18
NightfallG17
NightfallG17's Avatar
Drives: 2017 CAMARO ZL1
Sorry for the delayed reply of appreciation. Needless to say the last couple weeks have been more than out of the ordinary.
Thank you all for the feedback. I haven't had a chance to pull the wheels off yet as I have learned that more purchases are needed just to get the car jacked up.
(Patiently awaiting ZL1 AddOns Jack pads https://zl1addons.com/collections/jackpads-magpads)
I'll let ya'll know once I get a chance to use my new jack and lift pads..
Thanks again, appreciate everyone!
17' Nightfall Metallic Gray ZL1 / Stock-So Far / M6 / Alcantara everything / CF Insert / PDR / NAV
Most important part Britex multi-point car seat for little man & baby girl. Starting em young. "Go Fast Daddy"
NightfallG17 is offline   Reply With Quote
Old 05-13-2020, 02:06 AM   #19
Biscuit.fr
Drives: Red hot ZL1 A10 2017
Clean
Re-torque
No more noise...
https://static.nhtsa.gov/odi/tsbs/20...82871-5448.pdf
Biscuit.fr is offline   Reply With Quote
Old 05-15-2020, 11:06 PM   #20
NightfallG17
Just as everyone has said, I pulled the wheel off, brake cleaned, wiped everything down, applied a thin coat of anti seize, torqued to 140, and back in business.(No more Clicking)
Once again, appreciate all the comments and assistance..
Next order of business, Corsa Cat-back and kooks 2" headers.
Old 05-16-2020, 04:48 PM   #21
DFW_Muscle
Drives: 2018 Chevrolet Camaro ZL1
Torque applied won't change. So long as the force applied is uniaxial to the lugnut through the extension, the force is not reduced at all.
In theory, you could use an infinitely long and rigid extension on a torque wrench, and the torque at the handle is the torque applied to the nut.
DFW_Muscle is offline   Reply With Quote
