Old 04-14-2020, 12:10 AM   #15
caSStro18
Drives: 2018 Camaro SS
Originally Posted by ste1n View Post
Do you guys have a better picture or a better explanation of where those bolts are? I am going to take my car to a tire shop to have my summer wheels put on and I would like to have the tech look at it but I don't know how can I explain it precisely.
Behind the center cap on the rear wheels.
caSStro18 is offline   Reply With Quote
Old 04-14-2020, 12:46 AM   #16
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
these are 1 time use lock nuts. if it loosened it has to be replaced or it will just losses up again. part number 11612295
Old 04-14-2020, 07:07 AM   #17
appleman22
Drives: 2017 1ss 1le
i've made sure to mark mine and will return to check in a few thousand miles. I've tightened them on other gm products before with good success. Will report back!
appleman22 is offline   Reply With Quote
Old 04-14-2020, 11:10 AM   #18
MackSteelPrivateEye
Is their a TSB for this?
Old 04-14-2020, 11:14 AM   #19
appleman22
Not to my knowledge but there certainly should be as it seems like many have loose axle nuts
Old 04-14-2020, 04:52 PM   #20
DIYguy
DIYguy's Avatar
Drives: 2017 Camaro 1LT
Smile
I too have had success in other similar situations but will add it to the things I check at oil change time just in case.
My ancient 36mm socket happens to be a 12pt and it fit snugly.
But as Redlinez said, if you are going to purchase one definitely get a 6pt.
Gen6 Camaro LT (my daily driver), Cruze ECO (grocery getter), Chevy SS Pickup (wife's daily driver), Honda Shadow, Honda CBX
DIYguy is offline   Reply With Quote
Old 04-17-2020, 07:02 AM   #21
appleman22
Anyone know how we can spread this thread to other parts of the forums?
Old 04-20-2020, 11:01 PM   #22
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
So this really helps tighten up some of the excessive backlash/play/looseness in the drivetrain? I'm trying to see how this would eliminate that as the CV shaft will be splined in anyway?
I am going to check mine tomorrow and report back if they are loose or not.
cmitchell17 is offline   Reply With Quote
Old 04-21-2020, 07:16 AM   #23
appleman22
for me, it literally fixed all of my drivetrain slop
Old 04-21-2020, 10:35 AM   #24
MackSteelPrivateEye
What happens if they get loose and you don't know it? Any symptoms?
Old 04-21-2020, 10:40 AM   #25
AD17SS1LE
AD17SS1LE's Avatar
Drives: 2017 Camaro SS 1LE
Mine were also backed off the original mark, thank you for posting this!!
2017 Camaro SS 1LE
Pray ported TB/IM
TSP 1 7/8 Long tube headers w catted con pipes
Taylor plug wires
Mishimoto oil cooler
Elite X2 catch can
AD17SS1LE is offline   Reply With Quote
Old 04-21-2020, 10:57 AM   #26
appleman22
yeah, slop in the drivetrain and it will start eating your wheel bearings
Old 04-21-2020, 11:47 AM   #27
MackSteelPrivateEye
Any legit documentation on the internet I can copy and take to my dealer to show I'm not BS'ing him on having it checked. My car is still in warranty. (extended).
Old 04-21-2020, 12:49 PM   #28
2K16SummitSS
Resident Land Surveyor
2K16SummitSS's Avatar
Drives: 2016 Camaro 1SS - Summit White M6
I had a warranty claim for this issue a couple years ago. They claimed the noise was 'corrosion on the axles', but my suspicion is the nut was loose. Here we are in the present and the exact noise has reappeared, along with a bit of drivetrain slop. Car is far out of warranty now, but at least it should be an easy fix. I'm sure the dealership didn't replace the nut, and if it's TTY then that would explain why it backed off again. I will look into replacement for both sides just in case.
2016 Summit 1SS 49th Anniversary Commemorative Limited Plutonium Edition - M6, Solo Axleback & !RearCats, Ultra-Rare Cloth Seats, Forgestar CF5V 19x10-285/35 19x11-325/30
2001 NBM Trans Am WS6, Wifey's Grocery Getter - Torquer V2 cam, Racetronix Fuel Pump, Yank 3000 Stall, Transgo 1-2 kit, TSP LTs, Magnaflow, Strano Springs/Koni STR.T shocks, 17x9.5/17x11 TTIIs, Ed Wright tuned
2K16SummitSS is offline   Reply With Quote
