Old 03-23-2020, 10:45 AM   #15
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
Originally Posted by Nabush View Post
I can upload my tune and logs if someone thinks he has an idea other than heads
I would just log and send the file over to Pray and pay him to look at it. Your original mods look a tad low, I was thinking the minimum your should have on a mustang is 440 with your mods. The increase in Hp on cam looks good but your torque obviously looks jacked up. Something in your tune just because of low torque.
I am speaking of experience thru my last build and finding the right tuner. Went thru 3 tuners and then graduated to logging & remote tuning. Don’t get stuck on Dyno numbers, it’s the time at the track that matters if your drag racing.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 03-23-2020, 11:12 AM   #16
oldman
Drives: SS 6 speed of course
The cam he has is bigger than the biggest cam Cam Motion makes for a 6.2. A BTR Gen V 5.3 stage II cam is 206 / 212 on a 110 LSA. Ths engine is effectively only 5.6 liters. Unless the dynamic flow is constant, you have port / flow stagnation. This is a HUGE cam for stock heads and 5.6 liters. Last the cam he has should have peak HP at 7000 RPM, shift at 7400 RPM or so. He is running it to 6700 RPM, the cam is just wrong period, put it in cam doctor -10 duration in /ex would bring 35 ft -lbs in the midrange and may even make MORE HP at 6600 RPM where he lifts.
Old 03-23-2020, 11:20 AM   #17
BlackbeastSS2
It will be like my last build. A nice cars and coffee build, dam your car sounds mean. That was me, sounded like mean as shit but the track times didn’t shine until I used nitrous. If you don’t change your cam maybe nitrous if u want to improve your times. Instant HP
Old 03-23-2020, 11:33 AM   #18
6spdhyperblue
Drives: 2SS 1LE
What do u mean only 5.6 liters?
Old 03-23-2020, 11:39 AM   #19
easttxss
easttxss's Avatar
Drives: '16 2SS M6
Go back and read his other posts. He is talking in theory due to the altitude that this engine lives.
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB
'16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20)
'14 Fusion Titanium 2.0T
'83 Jeep Wagoneer
easttxss is offline   Reply With Quote
Old 03-23-2020, 12:51 PM   #20
6spdhyperblue
Drives: 2SS 1LE
Oh nice. Thx
Old 03-23-2020, 12:55 PM   #21
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
So is this cam not the VVT-3?
Old 03-23-2020, 02:12 PM   #22
oldman
it is. It has 235 intake on the TSP cam is much bigger than the 229 +3 degree advance on the biggest 6.2l Cam Motion. The TSP ca, is a BIG cam, also toss in the TSP has a much faster lift (not good on stock head), not even that great on a ported head (as an aside).
I will note the biggest TSP cam for the 5.3 gen V is 225 intake duration and peak power is at 6400 RPM.
" Intake Closing AGAIN!: The most important cam event. This sets the engine's effective RPM range, effective dynamic compression. An early closing (30 - 38 ABDC) = high dynamic compression, great low to mid RPM torque for a very broad power band, requires lower static compression (which means less stress and strain on the engine, less risk of heat damage and detonation, more reliability)"
https://tmfcycles.com/blogs/tech-tips/cams-explained
Old 03-23-2020, 02:23 PM   #23
oldman
Tick Performance Street Heat Stage 3 Camshaft for GenV LT Engines
233/239 | .646”/.635” | LSA114+2 | +32% Fuel Pump Lobe
Designed for: GenV LT Engines (as they're equipped with stock)
Basic Operating RPM Range: 2800-7200
Expected Horsepower Gains: 55-65RWHP over the stock camshaft in a well-optimized setup
Note what Tick is saying about their smaller cam (biggest one they sell), RPM 7200, if you are not going to rev the engine to 7200 RPM don't be looking for a 235 intake cam.
55 to 65 WHP on optimized setup. Conservative which is good.
Old 03-23-2020, 04:00 PM   #24
Nabush
Drives: 2017 C7 GS M7 / 2017 Camaro SS 1LE
Guys,
I'm not the only one to live at 2700 FT and use a TSP Stage 3 camshaft...
I'm sure the issue is not tuning related. I tried everything on the road and dyno, in all directions.
Timing : tried 10 deg to 26-27 deg of timing in this area. Way less torque at 10deg compared to 27 deg (as expected) I did not try more though as 27 is already a lot on 91 even at medium rpms.
Fuel : Lambda WOT at 0.90 or 0.83 no changes
SOI (start of injection) : advanced or retarded by more than 20 degrees in the area where I have issues. Not a bit of a change
Torque management : predicted torque actual torque commanded torque all match. No torque management timing pulled off. I tried to massage the tables just to see no changes.
My MAF table is calibrated within 1% and my VE tables around 2% on most of the cells I was able to hit during the hours I spent datalogging with my wideband attached to HP tuners. Not sure many tuners spend half the time I spent fine tuning that.
Looking back at old posts I've seen TSP stage 3 cam curves in the past looking like mine : it was before the ported heads, in 2014.
Pretty positive my issue is coming from the stock heads.
Ps : I don't drag race. I'm a roadcourse and AutoX guy. The real driving skills.
Nabush is offline   Reply With Quote
Old 03-23-2020, 05:05 PM   #25
BlackbeastSS2
I’m a Bi car racer when it comes to drag racing (where the thrills are) and road course. (Where u get dizzy around and around and around)
Altitude- move, turbos, supercharger, NOS. The only thing not to complain about altitude is that everyone else races at the same height so in reality it should not matter. On one hand you mode your car for your area and then go race at different location and you feel it. It’s either better or worse on the engine. Myself I am spoiled, Mission Raceway is 25 feet above sea level and 4200 length.
Old 03-23-2020, 06:01 PM   #26
KingLT1
KingLT1's Avatar
Guys,
I agree 2700ft isn't that high of altitude.
Have you changed the virtual torque tables?
I am sure ported heads with help but something still seems a miss buy how the power curve looks.
look at the power curve difference on this setup with the same cam but TSP cnc heads.
Old 03-23-2020, 06:03 PM   #27
Nabush
Yup. No changes.
Old 03-23-2020, 06:07 PM   #28
Nabush
Try AutoX. Really intense. No mistakes allowed. Need to be smooth and clean, tight and tidy.
Still prefer roadcourse, but AutoX is cheap and fun and really competitive.
