#15 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 18 ZL1 A10 Join Date: Nov 2008
Yup, I was right, if you drive in tour mode, you dont get the performance drive mode.
ZL1::J-E-T-S JETS JETS JETS |
#16 |
![]() Drives: '20 ZL1 M6 Join Date: Apr 2017
So on another note, I'm at a thousand miles now and I'm starting to really get on the gas.
The weather here has varied from mid 60's to high 80's. Today, the temp was indicating 89, and the car didn't feel that strong. I'm assuming that, like turbo cars, the supercharged ZL1 is noticeably affected by outside temp and heat soak, yes? Also, when I was winding it up in 2nd gear, at 6K rpm the boost gauge was between the 2nd and 3rd lines. Is this about right? I thought I would see close to the 15. I just want to be sure that everything is working properly since this is my first SC car. Thanks.
Mal
Ft. Lauderdale, FL '20 Camaro ZL1 M6 '22 Kawasaki ZX-14R |
#17 |
Life's Short, Live Fast!
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Nov 2016
Outside temp increase will reduce power a bit, but it feels like more compared to driving when it's cooler out, because the tires will also have more grip, so there is less spinning when you stab the throttle. Between the grip the car has and Chevy's street tuning, these cars really put the power down, and feel super planted.
You should have right around 10 psi peak boost. I think GM states 9.4 from the factory.
Full exhaust, lower pulley, E35 -10.36 at 133 mph 690 DA straight from the street with a slight spin at launch. TZQPHG '17 ZL1 HBM|A10|Nav|PDR|CFW Hood|ZL1 Mats 12/26/2016 Ordered! 2/8/2017 Built!! 3/2/2017 Brought Home!!! |
#18 | |
#19 | |
![]() Drives: 2019 Chevrolet Camaro ZL1 1LE Join Date: Sep 2019
I have 3k miles on mine now. I'm telling you, it definitely feels faster than it did with 1k miles on it! She will break in and start screaming!!
Check out my YouTube to see the ZL1 shenanigans!
https://www.youtube.com/channel/UCkm...3OKTzDGIAkqYxQ |
#20 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
No worries Mal about your ZL1!! The warm weather does have an effect on the car but since you are around 1000 miles the engine is still breaking in and will get better with more miles. My ZL1 is the first supercharged car I have owned and I can tell that mine is getting faster and running better since the mileage is almost 11,000. I have owned mine a little over a year and it is getting better with time! Hang in there and enjoy your new hotrod!
#21 |
Took the car out this morning. Boost gauge goes to just short of the third line, which right around 10 lbs if the gauge is accurate.
So, how do I get a couple more lbs?
Mal
#22 |
![]() ![]() ![]() ![]() Drives: 2018 Camaro ZL1 Join Date: Aug 2018
Tune or pulley swap.
#23 |
New supercharger, Maggie 2300/2650, or Whipple 2.9, or Edelbrock 2650, or...
The stock LT4 supercharger is small (1.7L), already spinning very fast and generates a lot of heat. I for one wouldn't pulley it just to reach 15 psi of boost that is at the end of the gauge scale.
#24 | |
Mal
