#15 | |
![]() ![]() Drives: The DSSV Twins: ZR2 and ZLE A10 Join Date: Oct 2019
#16 | |
More power would help but if you are at a race course you'll want to mod your cooling system first. These cars heat soak so fast an upgraded heat exchanger and a reservoir can help out a ton. Keep your intake temps down and your lap times will come down as well. You can be losing 25-40rwhp quicker then you think from your intake temps pulling timing. A tune can clean this up some too. |
#17 | |
![]() ![]() ![]() ![]() Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
Equivalent to 1:50 at Buttonwillow would be maybe a 1:28-1:29 at Big Willow. I don't have firsthand knowledge of fast ZLE laps at Big Willow, only Buttonwillow, Laguna Seca, Sonoma, and Auto Club Speedway in Fontana. |
#18 |
![]() Drives: 2018 Camaro ZL1 1LE Join Date: Aug 2018
track tires
I track (road course) my 2018 ZL1 1LE and am looking for some experience/advice re: tire options. I'm getting about 5 track days out of the factory GY's and I love the tires but I'll go bankrupt replacing them at this rate. Has anyone tried scrubs? If so, who do you get them from and how much are you spending?
Also, if you have switched to another brand for longevity and/or price what sort of success have you had? Have you had to sacrifice handling? Any thoughts at all are welcome guys...and gals, too! :-) |
#19 |
Sarcasm loading --------
Pro racers can get a 1:25 out of the car on this track; which I am not. I have been to big willow over 20 times in the last 20 years; although mostly on motorcycles.
the tires have 6k miles on them. I did not do the track alignment, I did not decide to go until the night before. all that was done was an oil change; which is unusual for me. I usually go all out on my track weekends. normally 2 day events, new tires, everything. i know it will run through the corners faster, but all im saying is that down the front straight it makes alot of noise - and not alot of "go". I was actually a little dissapointed by that.
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
#20 | |
#21 |
![]() ![]() ![]() ![]() ![]() Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
I’ve never tracked a car before so driving so I have no real clue what I’m talking about. With that said, if I wanted more power but not more heat, I would port the stock SC, larger 103tb, low side fuel, RF CAI/or even the big gulp, headers, flex fuel, tune. Should pick up a bunch of power and be even more efficient.
#22 |
![]() Drives: 19 ZLE A10,17 SS 1LE, 16 C7R,CT5V Join Date: Feb 2017
There is no good data on the regular SuperCars in the rain from the magazine companies, however, if you ever think your going to get stuck in the rain you cannot go wrong with the P4S.
The regular SuperCars fit in SCCA Sport 1 Class - in case anyone wants to know. |
#23 | |
![]() Drives: Camaro 1ss Join Date: Nov 2019
#24 |
#25 | |
![]() Drives: Tracks: 18' ZL1 1LE Join Date: Mar 2018
18' ZL1 1LE Red Hot track toy
Endless RF650 Ported TB/Rotofab dry intake AWE Track w/PLP APR GTC300 wing / Singular Endplates ASC Splitter / PA tunnels MFR Engineering Custom Diffuser Race Louvers Fender Vents Trackspec roll bar Various SPL suspension Hawk DTC 70/60 pads APEX SM10 & ARC8 For sale: 2018 OEM ZL1 1LE Wing 12' Nissan GT-R SOLD |
#26 | |
that or I need more octane and timing was pulled? I ran 91 in it.. Im not concerned with the lap times; every single lap involved a pass, or wait on another driver (pass only on straights). 10 mph lost down the front straight at the same track with the same driver and exit speed in a lighter car (with a slightly higher power to weight ratio) doesnt make sense to me. im kind of thinking I should dyno it. I would think it should be around 530 at the wheels stock?
#27 | |
#28 |
I mentioned this in an earlier post... the car IS tuned for 93 and Ted Jannetty tested the difference and I think he found a 25+ WHP difference. I add about 4 gallons of 100 at the track to avoid knock (especially on hot days), and get maximum power
