Old 07-12-2020, 06:01 AM   #15
RealG
RealG's Avatar
Drives: 2024 2SS
Is the factory strut tower option dealer installed ?
Thanks
RealG is offline   Reply With Quote
Old 07-12-2020, 12:22 PM   #16
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Thanks
It can be or you can install it yourself, takes about 15 minutes with some basic hand tools...
You can buy them here cheaper than the dealer:
https://www.shopchevyparts.com/perfo...-92304349.html
https://www.shopchevyparts.com/perfo...-92304348.html
Old 07-12-2020, 01:08 PM   #17
s346k
s346k's Avatar
Drives: like an old lady
fyi the mighty mouse setup comes with your choice of mounting location. and it's not a mishimoto part. win-win.
Old 09-16-2021, 06:23 AM   #18
JDaniels609
JDaniels609's Avatar
Drives: ‘22 2ss
I have the Mishimoto Catch Can and GM Performance Strut brace and both work fine together (I was worried about the same, but no issue...)
You can see them both below...
Sorry to bring this back from the dead but do you have to remove the strut bar to drain the catch can? Going to be installing both when my car arrives.
‘22 2SS A10
JDaniels609 is offline   Reply With Quote
Old 09-16-2021, 08:54 AM   #19
JOHNSONROD
JOHNSONROD's Avatar
Drives: 62 Chevy & 2021 1SS/1LE manual
ok, noone asked about the elite but i mounted it back there like yall did. i got the extra hose and ran it under the plastic cover on the left side. its clean.
JOHNSONROD is offline   Reply With Quote
Old 09-16-2021, 10:01 AM   #20
cheeze9878
cheeze9878's Avatar
Drives: 17 camaro ss
Hey guys, I was wondering how much of a pain in the ass it is to empty these when they are mounted way in the back under the strut bar?
cheeze9878 is offline   Reply With Quote
Old 09-16-2021, 10:22 AM   #21
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
i kept mine when i installed my catch can but had to remove mine when i got my coilovers and camber plates on
Old 09-16-2021, 11:27 AM   #22
s346k
s346k's Avatar
the mighty mouse can came with a drain hose & valve. i drop it down when changing the oil and drain it into the pan. ez pz.
Old 09-16-2021, 12:35 PM   #23
2SS Capt
2SS Capt's Avatar
It's not bad, I can reach the catch can and unscrew it without removing anything else. The Mishimoto does have a nut on the bottom that you could put a drain hose and valve on if you wanted to.
Basically I use 2 hand and reach on either side of the struct tower brace and can get about a quarter turn per try until it is loose then I just reach in from the front and unscrew it easily... I've emptied it probably 8-9 times this way, never a problem...
Old 09-17-2021, 07:40 PM   #24
Drizzt ss
Drizzt ss's Avatar
Drives: 2017 NGM 1SS MRC NPP
Just wanted to throw this on here since I didn’t see a pic of it. BMR brace with the mishimoto CC. And yep, gotta clean the engine bay, I feel much shame…
Mamo PTB /Borla ATAK NPP /Carbon Fiber lip/ZL1 side skirts/ Black Bow ties/Husky Mats/ Mishimoto CC /BMR strut tower brace/ZL-1 License relocation/Rock guards
Drizzt ss is offline   Reply With Quote
