Old 04-09-2020, 06:40 AM   #15
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Open the app. Then click on the gear icon and go into the settings area. Then go down to the "Manage extra PIDs/sensors and click it.
Click on the 3 dots in the right corner and click "add custom PID"
I hope this next part makes sense. One each of these sections in the custom PID fields add the data I have for each section. If there is nothing in the section, leave it blank.
- OBD2 mode and PID - 220052
- Long name - Ethanol %
- Short name - E85
- Minimium value - 0.0
- Max value - 100.0
- Scale Factor - 1x
- Unit type - %
- Equation - (A/255)*100
- OBD header - Leave blank
- Diagnostic start command - leave blank
- Diagnostic stop command - leave blank
- Overrides PID - Does not override any PID
- Remember equation function data - I used store value globally
That should be it, then you just need to add one of the graphs to your screen and choose the one you named E85.
Old 04-09-2020, 07:26 AM   #16
MRLZL1LE
MRLZL1LE's Avatar
Drives: 2018 Chevrolet Camaro ZL1 1LE 6MT
- Short name - E85
- Max value - 100.0
- Scale Factor - 1x
- Unit type - %
Thank you!!
2018 ZL1-1LE
Rotofab, Ported TB, 2.3 Pulley, ATI balancer w DSX 9.06 Lower ring, LME heads, 2" Kooks, custom cam, DOD Delete, Cordes Low side fuel system, Flex Fuel Kit, MM Catch can, ZL1 addons tow hook, ZL1 addons rock gaurds, Diode dynamics blacked out side markers
MRLZL1LE is offline   Reply With Quote
Old 04-09-2020, 01:02 PM   #17
Road Pressence
Road Pressence's Avatar
Drives: 2019 Satin Steel ZLE
Advanced fuel dynamics flex fuel kit, comes with a bluetooth link and you can see the E% on your phone in real time. Pretty easy and affordable.
https://www.advancedfueldynamics.com...31220368408712
Road Pressence is offline   Reply With Quote
Old 04-09-2020, 01:24 PM   #18
scantone
Drives: 18 Z1E - 18 Raptor - 17 Jeep SRT
Does something need to be turned on in the ECU to read the E% with a Ngauge?
scantone is offline   Reply With Quote
Old 04-05-2021, 11:29 PM   #19
MVPxD
MVPxD's Avatar
Drives: 2021 Camaro LT1
Originally Posted by Stephen12ZL1 View Post
$10 Amazon obd 2 dongle & $5 Android torque app
which obd 2 dongle do you use?
MVPxD is offline   Reply With Quote
