#15 |
Drives: 2018 ZL1 1LE Join Date: Jun 2012
I am running a 18' steel deck trailer with no issue, of course more room would always be nice for tools and fuel but my 18' can fit inside my garage and is slightly better for parking. I have no tongue weight issues, as others have said you definitely want some tongue weight so you don't end up with trailer sway and putting herself into a ditch at 80 on the highway.
#16 |
![]() ![]() ![]() ![]() ![]() Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold) Join Date: Nov 2016
Like others mentioned, tongue weight is important. I have no issues with my 16.5 ft tilt bed trailer, it's great for doing maneuvering in tight parking lots and backing up to my parking space.
#17 |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
18' is fine.
#18 | |
![]() Drives: ‘17 1LE, ‘17 BMW 340, ‘18 F-150 Join Date: Nov 2017
I'm tempted to get an Air Lift 59570 Ride Control kit.
2017 - SS 1LE
2015 - 2SS, RS, NPP, 1LE - Sold |
#19 | |
Hot Camaro
The WDH changes how the weight is transferred to the tow vehicle and allows more weight to remain on the front suspension. This improves handling and braking. I know from personal experience that the rear can squat quite a bit without changing the characteristics "too much." But I also know that a subtly incorrect placement of the cargo can throw the tongue weight and create big issues (I dragged about 6000 lbs on a 10k trailer (about 8500 lbs total) and the weight was just a touch too far back. I had no issues with sway, handling, or braking, but the rear tires didn't have as much grip as they should have and you had to be a little more gentle on the gas when pulling away from a stop on dirts roads / roads with dirt or gravel on them because it would slip a little. I pulled off to the side and used a very large ratchet strap to drag the cargo forward about an inch (wrapped around the rub rail and used the ratchet mechanism like a winch). Made a huge difference the rest of the way home. |
#20 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
I use ZL1 add ons strap points which work great.
