Old 02-12-2020, 01:18 PM   #15
L78toLT1
L78toLT1's Avatar
My trans has shifted flawlessly from day 1. Even though the oem fluid has performed well for me, I did call both Tremec and Tick Performance to see what they recommended. Both said to stick with the oem stuff, so that's what I did
Baby Blue
Old 02-12-2020, 02:04 PM   #16
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
sorry dude. I have RP syncromesh in mine and works better than the OE fluid. I changed it out around 3K.
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 02-12-2020, 03:04 PM   #17
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Thank you its probably just cold.
Old 02-12-2020, 10:53 PM   #18
DorkMissile
DorkMissile's Avatar
Drives: DZ
If it is worth mentioning - ever since the T56 came out, the Tremec really hasn't had a reputation for a cruising transmission. My Camaro was my first manual that I have had in awhile, and when I started thinking it was kind of crunchy going into 2nd, the advice I was given from a friend of mine who actually works at the GM Milford Prooving Grounds told me "These Tremecs are all like that. The synchros are really lightweight and the weight of the mechanism is much lighter than years ago. Don't flop the shifter into second - before pushing in the clutch, have a hold of the shifter with some pressure, and once the clutch is in, pull it all the way back with pressure until it stops moving"
Once trying to focus on it, I noticed it really wasn't that bad. When I get distracted from it, I notice I tend to not have as much luck.
DorkMissile is offline   Reply With Quote
Old 02-16-2020, 12:19 PM   #19
TRZ06
TRZ06's Avatar
Drives: 22' Porsche PDK GT4
I swapped to RP about 9 months ago. At first, it made a BIG difference, smooth as butter 90% of the time.
Now, it feels similar to the stock fluid again. I only get buttery smooth shifts about 50% of the time.
Some say it isn't a big deal, but over time it kinda is. It does detract from the driving experience some when you don't get that nice clean click into each gear and instead are met with a notchy slightly crunch feel.
My dream list for this car is a dual clutch, but that won't happen. I just can't do a traditional auto. For me its either a dual clutch or a manual.
Current:
Previous:
09' C6 Z06
08' E90 M3
06' 335i (KW V2 Coilovers)
03' C5 Z06
Old 02-16-2020, 12:38 PM   #20
6spdhyperblue
Drives: 2SS 1LE
Change your brake fluid
Old 02-16-2020, 05:24 PM   #21
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
It's been in 70s so it's been a lot better lately. For a cold climate it's a no go.
Old 02-17-2020, 10:06 AM   #22
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
Why change the brake fluid?
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw
MP3BOOSTED is offline   Reply With Quote
Old 02-17-2020, 10:25 AM   #23
6spdhyperblue
Drives: 2SS 1LE
It’s the same resi as the clutch fluid. Old fluid affects my shifting more than trans fluid
Old 02-18-2020, 06:55 PM   #24
TRZ06
TRZ06's Avatar
I think you are confused.
The clutch fluid is shared with the brake fluid, not the tranny fluid.
Current:
Previous:
09' C6 Z06
08' E90 M3
03' C5 Z06
Old 02-18-2020, 07:13 PM   #25
6spdhyperblue
Drives: 2SS 1LE
Yeah we were talking about the brake fluid. To clarify: the old clutch/brake fluid effects my shifting more than trans fluid.
I change my brake fluid often because of the clutch and less about the brakes.
Old 02-22-2020, 09:17 PM   #26
Whocares05050
Drives: 2018 Camaro SS 1LE
Im using RP and i have zero.issues
Whocares05050 is offline   Reply With Quote
Old 02-29-2020, 08:32 AM   #27
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
I’m using rp. No complaints. Not sure if it was worth switching, I’m not positive but I think it lowered my mpg! I bet it thins out quick and will get better.
As I’ve said for a long time I usually skip second gear unless needed and I never need it while I’m warming up the car. I keep getting flamed on for this, but I don’t see issues.
How often u bleed ur brakes?
I've got RP in the trans too, but it does seem to fade in its benefits as others have noted. But yes, I have also noticed that just a turkey baster brake bleed of the master cylinder will sharpen up shifts pretty quick.
The kids are grown and moved away- so another pair of hands for a proper bleed are more difficult... gotta son-in-law that may be capable. Bought a Motive PowerBleeder but its just a PIA waiting to make a mess, IMHO. Anyone want one for a good price- I'm negotiable!
Going over to Amazon now to get some Motul gear oil. Finally installing my Hurst shifter in a couple weeks and want change the tranny oil at the same time. Will report back as to results.
Ventmaster is offline   Reply With Quote
Old 02-29-2020, 08:39 AM   #28
6spdhyperblue
Drives: 2SS 1LE
Nice the hurst is a longer install than usual but it’s a pretty fun easy job. Just moving stuff, if u have a impact it helps. The shifter feel is worth it. Hurst did good
